294-3220_ALT_0
294-3220_ALT_1
Peavey BWX SC-12 Neodymium 12" Woofer Speaker
Brand:|Model: BWX SC-12|Part # 294-3220
Peavey's 12" BWX Neo subwoofer features a Kevlar® impregnated cellulose cone. The aluminum ribbon wire voice coil is wound on a polyimide-impregnated fiberglass former with Nomex® stiffener and solderless diffusion welded OFHC copper leads.
  • Lightweight neodymium magnet structure
  • Kevlar® reinforced cone for increased strength
  • Die-cast aluminum frame
  • High power handling
  • Polyimide-impregnated fiberglass former with Nomex® stiffener
  • 4" diameter aluminum ribbon voice coil
  • Solderless diffusion welded OFHC copper leads
Peavey's 12" BWX Neo subwoofer features a Kevlar® impregnated cellulose cone. The aluminum ribbon wire voice coil is wound on a polyimide-impregnated fiberglass former with Nomex® stiffener and solderless diffusion welded OFHC copper leads. Peavey item 00560850.
  • Nominal Diameter12"
  • Power Handling (RMS)650 Watts
  • Power Handling (max)1300 Watts
  • Impedance8 ohms
  • Frequency Response50 to 3,500 Hz
  • Sensitivity96.9 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)56.1 Hz
  • DC Resistance (Re)5.43 ohms
  • Voice Coil Inductance (Le)0.36 mH
  • Mechanical Q (Qms)9.51
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)1.93 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)15.13 Tm
  • Diaphragm Mass Inc. Airload (Mms)50.7g
  • Maximum Linear Excursion (Xmax)4.7 mm
  • Surface Area of Cone (Sd)520 cm²
  • Cone MaterialPaper / Kevlar
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • # Mounting Holes8
  • Sealed Volume0.75 ft.³
  • Sealed F3104 Hz
  • Vented Volume1.95 ft.³
  • Vented F354 Hz
  • BrandPeavey
  • ModelBWX SC-12
  • Part Number294-3220
  • UPC0014367136739
  • Weight13.9 lbs.
View similar products to the Peavey BWX SC-12 Neodymium 12" Woofer Speaker
