Peavey BWX SC-10 Neodymium 10" Woofer Speaker
Brand:|Model: BWX SC-10|Part # 294-3222
Peavey's 10" BWX Neo subwoofer features a Kevlar® impregnated cellulose cone. The aluminum ribbon wire voice coil is wound on a polyimide-impregnated fiberglass former with Nomex® stiffener and solderless diffusion welded OFHC copper leads.
  • Lightweight neodymium magnet structure
  • Kevlar® reinforced cone for increased strength
  • Die-cast aluminum frame
  • High power handling
  • Polyimide-impregnated fiberglass former with Nomex® stiffener
  • 4" diameter aluminum ribbon voice coil
  • Solderless diffusion welded OFHC copper leads
  • Nominal Diameter10"
  • Power Handling (RMS)650 Watts
  • Power Handling (max)1300 Watts
  • Impedance8 ohms
  • Frequency Response50 to 4,000 Hz
  • Sensitivity94.5 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)59.3 Hz
  • DC Resistance (Re)5.48 ohms
  • Voice Coil Inductance (Le)0.44 mH
  • Mechanical Q (Qms)8.16
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.92 ft.³
  • Mechanical Compliance of Suspension (Cms)0.16 mm/N
  • BL Product (BL)15.59 Tm
  • Diaphragm Mass Inc. Airload (Mms)44g
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)340 cm²
  • Cone MaterialPaper / Kevlar
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialNeodymium
  • # Mounting Holes8
  • BrandPeavey
  • ModelBWX SC-10
  • Part Number294-3222
  • UPC0014367136760
  • Weight14 lbs.
View similar products to the Peavey BWX SC-10 Neodymium 10" Woofer Speaker
