299-463_ALT_0
299-463_ALT_1
Peavey Bullet Super Tweeter with 80 degree Conical Horn
Brand:|Model: 00573880|Part # 299-463
Choose this super tweeter from Peavey for extended frequency response applications from 3,500 to 20,000 Hz. It's paired with a conical horn through this Parts Express exclusive buyout, and you can save up to 25% off the original retail price!
  • Focused high frequency output with high SPL
  • Fluid cooled voice coil for high power handling
  • Includes conical horn
Peavey's high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling, controlled low frequency behavior and long-term reliability are assured. This super tweeter is pre-mounted on an outside-threaded 80° conical horn for focused output.
Save up to 25% off the original retail price through this Parts Express exclusive buyout. Quantities are limited.
Note: The compression driver portion of this tweeter is designed only to be used with the included 80° conical horn. It will not mount to standard Professional Audio horns.
Specifications: • Power handling: 45 watts RMS (crossover frequency 3.5 kHz, 18 dB/octave), 85 watts RMS (crossover frequency 5 kHz, 18 dB/octave) • Impedance: 8 ohms • Sensitivity: 105 dB • Useable range: 3,500-20,000 Hz • Fs: 2,500 Hz • Recommended crossover: 3,500 Hz • Dimensions: 3-7/16" H x 3-7/16" W x 3-5/8" D • Cutout dimensions: 3-1/8" diameter.
  • Diaphragm MaterialPhenolic
  • Impedance8 ohms
  • Power Handling (RMS)45 Watts
  • BrandFactory Buyouts
  • Model00573880
  • Part Number299-463
  • UPC848864007809
  • Product CategoryHorn Loaded Bullet Tweeters
  • Weight1.6 lbs.
View similar products to the Peavey Bullet Super Tweeter with 80 degree Conical Horn
in the Horn Loaded Bullet Tweeters product category.
