Peavey BTS 2.2 Bluetooth Wireless Speaker USB SD Card Music System White
Brand:|Model: BTS 2.2 |Part # 248-8323
Take your music with you and get world-class sound wherever you go, with the first name in high quality audio, Peavey!
  • Small footprint - big sound
  • 8.5 hours play time on a single charge
  • MP3 and WMA playback from USB or SD/TF card
  • Headphone jack for discreet enjoyment
  • Bluetooth range up to 33 feet
The battery-powered Peavey BTS 2.2 will play music from a USB drive, SD card, 3.5mm source or Bluetooth for true wireless sound reproduction. Small enough to fit practically anywhere and weighing well under 1 lb., the BTS 2.2 gives you more than eight hours of continuous music on a single charge, with clear, true Peavey sound. Peavey item 03017010.
Specifications: Bluetooth version: V2.1 + EDR (backward compatible) • Frequency band: 2400 – 2483.5 MHz • Working range: 10 meters (33 Feet) • Charging voltage: 5V DC (USB) • Bluetooth profiles: A2DP, HSP, HFP, AVRCP • Internal battery: 3.7 volt rechargeable lithium • Input: 3.5 mm aux jack • Output: 3.5 mm headphone jack • Rated power: 2W x 2 drivers • Audio playback format: MP3 / WMA • Storage capacity: USB and SD/TF card <32GB • Speaker: magnetically shielded D40mm (4 ohms) / 2 • Battery charge time: approx. 3.5 hours • Play time: approx 8.5 hours • Battery voltage/capacity: 850 mAh • Device ID: PY-11BT • Size: 7.165" x 2.283" x 1.3" • Weight: 10.47 oz.
  • Special FeaturesBluetooth Wireless,Powered
  • Woofer Diameter1-1/2"
  • ConfigurationFull-range
  • ColorWhite
  • BrandPeavey
  • ModelBTS 2.2
  • Part Number248-8323
  • UPC014367617627
  • Product CategoryPortable Powered Speakers
    (1 Reviews)
  • Weight0.95 lbs.
