Peavey BTS 2.2 Bluetooth Wireless Speaker USB SD Card Music System Black
Brand:|Model: BTS 2.2|Part # 248-8321
Take your music with you and get world-class sound wherever you go, with the first name in high quality audio, Peavey!
List Price$99.99
You Save20%
$79.99
Part # 248-8321
  • Small footprint - big sound
  • 8.5 hours play time on a single charge
  • MP3 and WMA playback from USB or SD/TF card
  • Headphone jack for discreet enjoyment
  • Bluetooth range up to 33 feet
The battery-powered Peavey BTS 2.2 will play music from a USB drive, SD card, 3.5mm source or Bluetooth for true wireless sound reproduction. Small enough to fit practically anywhere and weighing well under 1 lb., the BTS 2.2 gives you more than eight hours of continuous music on a single charge, with clear, true Peavey sound. Peavey item 03017000.
Specifications: Bluetooth version: V2.1 + EDR (backward compatible) • Frequency band: 2400 – 2483.5 MHz • Working range: 10 meters (33 Feet) • Charging voltage: 5V DC (USB) • Bluetooth profiles: A2DP, HSP, HFP, AVRCP • Internal battery: 3.7 volt rechargeable lithium • Input: 3.5 mm aux jack • Output: 3.5 mm headphone jack • Rated power: 2W x 2 drivers • Audio playback format: MP3 / WMA • Storage capacity: USB and SD/TF card <32GB • Speaker: magnetically shielded D40mm (4 ohms) / 2 • Battery charge time: approx. 3.5 hours • Play time: approx 8.5 hours • Battery voltage/capacity: 850 mAh • Device ID: PY-11BT • Size: 7.165" x 2.283" x 1.3" • Weight: 10.47 oz.
  • Special FeaturesBluetooth Wireless,Powered
  • Woofer Diameter1-1/2"
  • ConfigurationFull-range
  • ColorBlack
  • BrandPeavey
  • ModelBTS 2.2
  • Part Number248-8321
  • UPC014367617610
  • Product CategoryPortable Powered Speakers
    (3 Reviews)
  • Weight0.84 lbs.
View similar products to the Peavey BTS 2.2 Bluetooth Wireless Speaker USB SD Card Music System Black
in the Portable Powered Speakers product category.
Peavey BTS 2.2 Bluetooth Wireless Speaker USB SD Card Music System Black is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from Excellent QualityHaven't had it long but initial impression is that it is very nice quality build and big, clear sound coming from a very small box! Especially like the SD card slot.
Date published: 2015-02-23
Rated 5 out of 5 by from Peavey BTS 2.2Nice Bluetooth portable speaker. It very versatile because it can also play SD/TF memory card music and accept auxiliary audio in. Best feature is the earphone out...yes one of few cost affordable portable speaker systems that has earphone OUT.
Date published: 2014-06-27
Rated 4 out of 5 by from Great little boxI listened to this all day today using a USB stick. It has good sound (no bass, but what do you expect with 1" speakers?). The instructions are a bit vague, but its fairly easy to figure out.The only thing I don't like is that it won't play while charging.It would be cool if it had a mic for bluetooth mode, too, so you could use it like a speaker phone.
Date published: 2013-09-15
  • 2016-02-12T06:21CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_248-8321, PRD, sort_mostRecent
What is the size of this product. It is not listed in the specs.
Asked by: VinceG
Date published: 2014-12-16
  • 2016-02-12T07:06CST
  • loc_en_US, sid_248-8321, PRD, sort_recentQuestionsFirst
