294-307_ALT_0
294-307_ALT_1
Peavey 1808-8 CU BWX 18" Woofer Speaker Driver
Brand:| Model: 1808-8 CU BWX
High efficiency 18" woofer that excels in both vented and horn-loaded bass enclosures. Designed to work in small vented enclosures (3.5 to 6.5 cu. ft.) with surprising bass extension and very high output.
  • Field-replaceable basket
  • Kevlar® reinforced cones for increased strength
  • Polyimide-impregnated fiberglass former for higher sensitivity and frequency response
  • Die-cast aluminum frame
  • High power handling
  • 4" diameter edge-wound copper ribbon wire voice coil
  • Solderless diffusion welded OFHC copper leads
294-307
Weight: 21 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$229.99
You Save20%
$183.99
Part # 294-307
High efficiency 18" woofer that excels in both vented and horn-loaded bass enclosures. Designed to work in small vented enclosures (3.5 to 6.5 cu. ft.) with surprising bass extension and very high output. Great for DJs and musical instrument applications.
  • Nominal Diameter18"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 1,000 Hz
  • Sensitivity97.7 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)35.1 Hz
  • DC Resistance (Re)5.93 ohms
  • Voice Coil Inductance (Le)0.66 mH
  • Mechanical Q (Qms)9.93
  • Electromagnetic Q (Qes)0.35
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)11.04 ft.³
  • Mechanical Compliance of Suspension (Cms)0.14 mm/N
  • BL Product (BL)23.12 Tm
  • Diaphragm Mass Inc. Airload (Mms)143.2g
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)1240 cm²
  • Cone MaterialPaper / Kevlar
  • Magnet MaterialFerrite
  • Overall Outside Diameter18.25"
  • Baffle Cutout Diameter16.75"
  • Depth6.38"
  • # Mounting Holes8
  • Sealed Volume1.89 ft.³
  • Sealed F389 Hz
  • Vented Volume4.79 ft.³
  • Vented F354 Hz
  • BrandPeavey
  • Model1808-8 CU BWX
  • Part Number294-307
  • UPC0014367124408
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (5 Reviews)
  • Weight21 lbs.
View similar products to the Peavey 1808-8 CU BWX 18" Woofer Speaker Driver
in the Woofers, Subwoofers & Midrange Speakers product category.
Peavey 1808-8 CU BWX 18" Woofer Speaker Driver is rated 4.4 out of 5 by 5.
Rated 4 out of 5 by from Solid speakerI own a pair of these and use them for FOH subs. Very good bottom end. I can really FEEL the bass pounding. I don't know how you can beat the overall value of this speaker. You get a lot of BOOM for your buck.
Date published: 2009-06-27
Rated 5 out of 5 by from great speakergood ol' reliable black widow's, backbone of rock n roll
Date published: 2008-09-01
Rated 4 out of 5 by from Great value as usualThe Peavey Cu Bwx performs and sounds like the traditional Black Widow. As a matter of fact it is so much like the traditional black widow that I fail to see why peavey felt there was a reason to produce this speaker. They should have just improved the traditional black widow. I can't tell the difference except perhaps a little bit less distortion and a bit more power to handle. You can't beat the price/performance ratio as with all peavey speakers.I am glad to see Peavey make more speaker models but this one is perhaps unnecessary. But I bought one.
Date published: 2008-05-29
Rated 5 out of 5 by from Harder Thump Of Sound Not To The WalletI installed these into two Yamaha single 18" sub cabnets to replace blown speakers. Reconing was gonna cost 119.00. Why not try new?I was amazed at the difference in the performance of the Peavey 18" over the Yamaha. Deeper harder thump with a little less power was realized right from the start. After about 12 hours of combined playing time they actually further increased in performance.I am now at the point where I have removed them and am working through the speaker opening to beef up the box. They hit so hard the cab's are buzzing.I recommend this speaker for a replacement on small to medium venues.Bob
Date published: 2007-12-30
Rated 4 out of 5 by from Great product for a cheap priceThis speaker sounds amazingly deep bass. Put it in an old school PV SUBCOMPACT folded horn type cabinet, you can feel vibration in your chest.
Date published: 2007-12-24
what is the speaker displacement for the 1808-8 CU when front mounted? Specs are for rear mounted.
Asked by: Snoid
Peavey does not provide a front mounted displacement figure although the difference will be negligible and make no audible difference.
Date published: 2013-05-24
Customer projects that include: Peavey 1808-8 CU BWX 18" Woofer Speaker Driver
