Peavey 16.5V AC Power Supply 03013830
Brand:|
16 to 16.5 volt AC power supply at 1000mA equipped with 2.1 mm barrel-type connector. Internal one-shot thermal fuse protection.
248-8696
Weight: 1.15 lbs.
IN STOCK
$16.98
Part # 248-8696
  • AC Output Voltage16V,16.5V
  • Current Capacity1000 mA
  • Center/Tip PolarityAC
  • Plug Size2.1 x 5.5 mm
  • Input Voltage110~120 VAC
  • BrandPeavey
  • Part Number248-8696
  • UPC0014367611533
  • Product CategoryAC/DC Power Adapters
    (5 Reviews)
  • Weight1.15 lbs.
View similar products to the Peavey 16.5V AC Power Supply 03013830
in the AC/DC Power Adapters product category.
Peavey 16.5V AC Power Supply 03013830 is rated 5.0 out of 5 by 5.
Rated 5 out of 5 by from Fits my Peavey Spectrum Bass Module perfectly!!I needed this AC adaptor for a Peavey Spectrum Bass Module that I bought that came without the adaptor. It fit perfectly!
Date published: 2014-06-20
Rated 5 out of 5 by from perfectExactally what I needed and great people and came right away and the price was good. T.N. MN.
Date published: 2014-03-04
Rated 5 out of 5 by from Peavey 16.5V AC Power SupplyI am happy I found it. I use it on a Sound Mixer Peavey PV-8.
Date published: 2013-07-05
Rated 5 out of 5 by from Says what it does on the tinI have a Peavey PV6 (non usb) mixer but couldn't use it due it needing a power suppy (the last one blew), so I thought I'd do a search via google and this showed up. I bought it on a hunch and glad I did as I'm now rocking the mixer again!!
Date published: 2013-01-31
Rated 5 out of 5 by from Delivered fast, works as advertisedIt's a power supply. It works. I am satisfied. Bought for a piece of gear I hadn't used in years (due to not having a power supply). Plugged it in with this new adapter, and it worked. Except for I had forgotten that the LCD panel on my device had burned out, so it's still unusable for all intents and purposes, but the AC adapter works great...
Date published: 2012-12-22
Good day, I have a PV8 music mixer and the power adapter. Will the Peavey adapter model# 03013830 work as a substitute?
Asked by: MonteCristo
As long as the mixer requires 16.5 VAC and at or below 1000 mA input, and uses a 2.1mm x 5.5mm plug, this adapter will work fine.
Date published: 2014-06-25
peavey line mix 8 channel mixer has 16volt ac 25watt on unit at plug .Can I use 16vac 1100mamp adapter for this ?
Asked by: slyck
Yes this will work for that application.
Date published: 2014-04-14
will this power supply work on my addverb11 effect prossesor.
Asked by: wolffy
Unfortunately I do not know any of the specs for this device and what type of power adapter it requires.
Date published: 2014-02-19
Will this power supply work with a Peavey Bass Fex. It needs a 16.5V AV 1 amp power supply.
Asked by: Tom Gray
This is a 16.5VAC 1 amp power supply. 1000mA=1amp. You would just have to verify the barrel connector size is correct.
Answered by: RAK Audio
Date published: 2011-12-04
Customer projects that include: Peavey 16.5V AC Power Supply 03013830
