Peavey 1508-8 CU BWX 15" Woofer Speaker Driver
Brand:|Model: 1508-8 CU BWX|Part # 294-309
Rugged and efficient 15" woofer for larger (4.5 to 8 cu. ft.) vented boxes. The extended frequency response makes the 1508-8 CU BWX ideal as a replacement speaker, as well as for new designs.
  • Field-replaceable basket
  • Kevlar® reinforced cones for increased strength
  • Polyimide-impregnated fiberglass former for higher sensitivity and frequency response
  • Die-cast aluminum frame
  • High power handling
  • 4" diameter edge-wound copper ribbon wire voice coil
  • Solderless diffusion welded OFHC copper leads
Rugged and efficient 15" woofer for larger (4.5 to 8 cu. ft.) vented boxes. The extended frequency response makes the 1508-8 CU BWX ideal as a replacement speaker, as well as for new designs. Peavey item 00560160.
  • Nominal Diameter15"
  • Power Handling (RMS)500 Watts
  • Power Handling (max)2000 Watts
  • Impedance8 ohms
  • Frequency Response35 to 2,000 Hz
  • Sensitivity97.2 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)36.7 Hz
  • DC Resistance (Re)5.91 ohms
  • Voice Coil Inductance (Le)0.58 mH
  • Mechanical Q (Qms)9.31
  • Electromagnetic Q (Qes)0.3
  • Total Q (Qts)0.29
  • Compliance Equivalent Volume (Vas)7.05 ft.³
  • Mechanical Compliance of Suspension (Cms)0.19 mm/N
  • BL Product (BL)20.84 Tm
  • Diaphragm Mass Inc. Airload (Mms)93.9g
  • Maximum Linear Excursion (Xmax)4.7 mm
  • Surface Area of Cone (Sd)840 cm²
  • Cone MaterialPaper / Kevlar
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14"
  • Depth4.97"
  • # Mounting Holes8
  • Sealed Volume0.83 ft.³
  • Sealed F3110 Hz
  • Vented Volume1.9 ft.³
  • Vented F370 Hz
  • BrandPeavey
  • Model1508-8 CU BWX
  • Part Number294-309
  • UPC014367124736
    (1 Reviews)
  • Weight17 lbs.
View similar products to the Peavey 1508-8 CU BWX 15" Woofer Speaker Driver
