Peavey 15" Pro Rider CU CP Subwoofer Speaker Driver
Brand:|Model: 15" Pro Rider CU CP|Part # 294-305
The Pro Rider™ 15" woofer provides the perfect balance of sensitivity, excursion, and power handling for many 2-way and 3-way applications. Efficient, high-impact bass in smaller vented enclosures.
List Price$219.99
You Save20%
$175.99
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 294-305
  • Field-replaceable basket
  • Kevlar® reinforced cones for increased strength
  • Lower distortion due to greater damping of excess cone vibrations
  • Polyimide-impregnated fiberglass former for higher sensitivity and frequency
  • Die-cast aluminum frame
  • Higher power handling
  • 4" diameter edge-wound copper ribbon wire voice coil
The Pro Rider™ 15" woofer provides the perfect balance of sensitivity, excursion, and power handling for many 2-way and 3-way applications. Efficient, high-impact bass in smaller vented enclosures. Features a copper ribbon wire voice coil, Kevlar® reinforced cone, and extended frequency response. Peavey item 00560250.
  • Nominal Diameter15"
  • Power Handling (RMS)600 Watts
  • Power Handling (max)2400 Watts
  • Impedance8 ohms
  • Frequency Response35 to 2,000 Hz
  • Sensitivity97.9 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)34.8 Hz
  • DC Resistance (Re)5.7 ohms
  • Voice Coil Inductance (Le)0.51 mH
  • Mechanical Q (Qms)8.78
  • Electromagnetic Q (Qes)0.24
  • Total Q (Qts)0.24
  • Compliance Equivalent Volume (Vas)7.34 ft.³
  • Mechanical Compliance of Suspension (Cms)0.1 mm/N
  • BL Product (BL)22.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)100.5g
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)840 cm²
  • Cone MaterialPaper / Kevlar
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14"
  • Depth6"
  • # Mounting Holes8
  • Sealed Volume0.56 ft.³
  • Sealed F3127 Hz
  • Vented Volume1.22 ft.³
  • Vented F382 Hz
  • BrandPeavey
  • Model15" Pro Rider CU CP
  • Part Number294-305
  • UPC014367094312
    (2 Reviews)
  • Weight18 lbs.
