Peavey 15" Low Rider Subwoofer Speaker Driver
Brand:|Model: 15" Low Rider|Part # 294-303
Peavey's new Low Rider® 15" subwoofer delivers big-woofer output in a compact package. 800 watts RMS power handling, Kevlar® impregnated cone, cast aluminum frame, and high Xmax capability for performance that doesn't quit.
OUT OF STOCK
Due In: 8/10/2016
List Price$243.99
You Save20%
$195.19
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
*Domestic US orders only
Part # 294-303
  • Field-replaceable basket
  • Kevlar® reinforced cones for increased strength
  • Lower distortion due to greater damping of excess cone vibrations
  • Polyimide-impregnated fiberglass former for higher sensitivity and frequency response
  • Die-cast aluminum frame
  • Higher power handling
  • 4" diameter edge-wound copper ribbon wire voice coil
Peavey's new Low Rider® 15" subwoofer delivers big-woofer output in a compact package. 800 watts RMS power handling, Kevlar® impregnated cone, cast aluminum frame, and high Xmax capability for performance that doesn't quit. Flat response to 37 Hz in a 4.5 cu. ft. vented enclosure. Peavey item 00560310.
  • Nominal Diameter15"
  • Power Handling (RMS)800 Watts
  • Power Handling (max)3200 Watts
  • Impedance8 ohms
  • Frequency Response30 to 1,000 Hz
  • Sensitivity93.6 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)33.9 Hz
  • DC Resistance (Re)6.21 ohms
  • Voice Coil Inductance (Le)0.82 mH
  • Mechanical Q (Qms)10.67
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)5.48 ft.³
  • Mechanical Compliance of Suspension (Cms)0.15 mm/N
  • BL Product (BL)22.73 Tm
  • Diaphragm Mass Inc. Airload (Mms)142.3g
  • Maximum Linear Excursion (Xmax)9.6 mm
  • Surface Area of Cone (Sd)840 cm²
  • Cone MaterialPaper / Kevlar
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14"
  • Depth5.25"
  • # Mounting Holes8
  • Sealed Volume1.03 ft.³
  • Sealed F383 Hz
  • Vented Volume2.67 ft.³
  • Vented F349 Hz
  • BrandPeavey
  • Model15" Low Rider
  • Part Number294-303
  • UPC0014367124712
    (4 Reviews)
  • Weight23 lbs.
View similar products to the Peavey 15" Low Rider Subwoofer Speaker Driver
