New Product
Peavey 15" Low Max Subwoofer Speaker Driver
Brand:| Model: 15" LO MAX
The Peavey Lo Max® 15" subwoofer speaker includes a Kevlar®-impregnated cone for increased strength. This subwoofer also has a cast aluminum frame, and more.
294-3102
Weight: 37.15 lbs.
OUT OF STOCK
Due In: 10/28/2014
List Price$443.99
You Save20%
$355.19
Peavey Baseball Cap
Qty: 1Part # 520-302
List Price:$19.99
Part # 294-3102
Finally, there’s a subwoofer driver that just might be stronger than your biggest amplifier. With an almost inconceivable power handling capacity of 2400 watts program, the Lo Max has more real world power handling than any other commercially available sound reinforcement loudspeaker. A no compromise design combines this power capacity with high efficiency, excellent frequency response and low distortion for revolutionary performance. It even works well in compact enclosures. Peavey item 00560290.
  • Nominal Diameter15"
  • Power Handling (RMS)1200 Watts
  • Power Handling (max)4800 Watts
  • Impedance8 ohms
  • Frequency Response40 to 400 Hz
  • Sensitivity95.1 dB 1W/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)38.5 Hz
  • DC Resistance (Re)5.4 ohms
  • Voice Coil Inductance (Le)0.75 mH
  • Mechanical Q (Qms)11
  • Electromagnetic Q (Qes)0.36
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)4.38 ft.³
  • Mechanical Compliance of Suspension (Cms)0.11 mm/N
  • BL Product (BL)23.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)146g
  • Maximum Linear Excursion (Xmax)10.2 mm
  • Surface Area of Cone (Sd)890 cm²
  • Cone MaterialPaper / Kevlar
  • Voice Coil Wire MaterialAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.25"
  • Baffle Cutout Diameter14.125"
  • Depth7.5"
  • # Mounting Holes8
  • Sealed Volume0.99 ft.³
  • Sealed F388 Hz
  • Vented Volume2.19 ft.³
  • Vented F352 Hz
  • BrandPeavey
  • Model15" LO MAX
  • Part Number294-3102
  • UPC014367124866
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (1 Reviews)
  • Weight37.15 lbs.
View similar products to the Peavey 15" Low Max Subwoofer Speaker Driver
in the Woofers, Subwoofers & Midrange Speakers product category.
Peavey 15" Low Max Subwoofer Speaker Driver is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Worth the investmentAlthough recomended for vented boxes I put them in a sealed box an drove them from 8am untill 6:30pm outher brand name speakers failed but the low max are still going 3 years later. Im slowly converting all my speakers to Peavey low max.
Date published: 2011-08-08
What is the best cab to put the peavey low max1" sub into ??,could I make my own? Thanks . John
Asked by: JohnnyBoy123
Yes you certainly could build your own cab for this. I would recommend 4.8 cubic feet before driver and port displacement with three 4" diameter ports that are 16" long each for a tuning frequency of 35 Hz.
Date published: 2014-04-22
Customer projects that include: Peavey 15" Low Max Subwoofer Speaker Driver
Manuals / Resources
