299-461_ALT_0
299-461_ALT_1
Peavey 15" DVC Professional Woofer 8 Ohm per Coil
Brand:|Model: 00574860|Part # 299-461
This dual voice coil 15" woofer was designed by Peavey to be used in large cabinets, such as a jukebox. A high 0.96 Qts also allows you to use this woofer in open-back, dipole speaker systems in stereo 8 ohm, parallel 4 ohm, and series 16 ohm configurations. Save up to $40 off the original price!
  • High Qts for infinite baffle and open-back dipole speakers
  • Large 2-1/2" dual voice coil on a polyimide former with a vented pole piece for cooling
  • Can be wired in stereo 8 ohm, parallel 4 ohm, or series 16 ohm configurations
Peavey designed this 15" dual voice coil woofer for large sealed cabinet, low frequency reproduction. A Qts figure of 0.96 (measure with both voice coils wired in parallel) makes this speaker an ideal choice for applications such as jukebox installation, where one large DVC driver is used to support a smaller stereo set of speakers.
Additionally, this versatile 15" Peavey woofer can be used as an open-back dipole woofer in stereo 8 ohm, parallel 4 ohm, or series 16 ohm configurations, as well as a bass guitar speaker. Peavey's part number for this woofer is 00574860.
A paper cone and cloth surround were chosen to recreate the warm, natural sound that many classic speakers had, while a vented pole piece cools the 2-1/2" diameter voice coil and reduces power compression. Save up to $40 off the original retail price on this Parts Express exclusive buyout. Quantities are extremely limited!
Note: Specifications below are listed with voice coils wired in parallel.
  • Nominal Diameter15"
  • Power Handling (RMS)200 Watts
  • Power Handling (max)400 Watts
  • Impedance8+8 ohms
  • Frequency Response40 to 2,000 Hz
  • Sensitivity96 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Resonant Frequency (Fs)41.72 Hz
  • DC Resistance (Re)3.81 ohms
  • Voice Coil Inductance (Le)0.74 mH
  • Mechanical Q (Qms)7.94
  • Electromagnetic Q (Qes)1.09
  • Total Q (Qts)0.96
  • Compliance Equivalent Volume (Vas)9.66 ft.³
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.125"
  • Baffle Cutout Diameter13.875"
  • Depth5.75"
  • Bolt Circle Diameter14.625"
  • # Mounting Holes8
  • Sealed Volume15.33 ft.³
  • Sealed F342 Hz
  • BrandPeavey
  • Model00574860
  • Part Number299-461
  • UPC848864007793
  • Weight12.35 lbs.
View similar products to the Peavey 15" DVC Professional Woofer 8 Ohm per Coil
