Peavey 14XT Compression Driver
Brand:|Model: 14XT|Part # 294-3134
Specifications: • VCdia: 1.4" • Throat Parameter: 1" / 25 mm • Nominal Impedance: 8 ohms • Minimum Impedance: 7.1 ohms • DC Resistance: 6.8 ohms • Power Capacity (1000 Hz to 20,000 Hz): 100 watts peak, 50 watts program, 25 watts continuous.
List Price$67.99
You Save20%
$54.39
Part # 294-3134
Peavey item 00442510.
Specifications: • VCdia: 1.4" • Throat Parameter: 1" / 25 mm • Nominal Impedance: 8 ohms • Minimum Impedance: 7.1 ohms • DC Resistance: 6.8 ohms • Power Capacity (1000 Hz to 20,000 Hz): 100 watts peak, 50 watts program, 25 watts continuous • Sensitivity: 102 dB SPL 1 watt at 1 meter On-axis on 90º H x 45º V horn • Nominal Efficiency: 30% • Frequency Response: 1 kHz to 18,000 Hz • Recommended Crossover: 1,800 Hz at 12 dB / Octave • Lowest Recommended Crossover: 1,000 Hz at 12 dB / Octave • Diaphragm: Commercially pure titanium • VCdia: 1.4" / 35.5 mm • Voice Coil Material: Edge-wound ribbon with high temp Kapton bobbin • Flux Density: 11,500 gauss (1.15T) • Dimensions: 3.500" (91.44 mm) diameter x 2.75" (69.85 mm) depth • Horn Coupling Diameter: 7/8" (22.2 mm) • Horn Coupling Threads: Standard 1 3/8" – 18".
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialTitanium
  • Impedance8 ohms
  • Power Handling (RMS)50 Watts
  • BrandPeavey
  • Model14XT
  • Part Number294-3134
  • UPC014367041156
  • Product CategoryHorn Drivers
  • Weight2.2 lbs.
View similar products to the Peavey 14XT Compression Driver
in the Horn Drivers product category.
Part # 294-3134
