Bonus Item Incl.
300-7066_ALT_0
Parts Express Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
Build your own tower speaker cabinet in minutes with this CNC-cut cabinet.
  • CNC-cut, acoustically inert MDF panels for precise fit and finish
  • 1.16 cu. ft. internal volume
  • Build your own tower or large format center channel speaker
  • Assembles in minutes
  • Made in the U.S.A.
300-7066
Weight: 27.75 lbs.
IN STOCK
List Price$79.99
You Save18%
$65.74
Buy 3-up$63.33
Grip Tools 32081 36" Quick Ratcheting Bar Clamp
Qty: 1Part # 365-114
List Price:$9.89
Part # 300-7066
CNC knock-down cabinets make it easy for the beginner to end up with amazing finished results without all of the time and effort necessary to perfect your woodworking skills, perfect for DIYers without expensive tools or access to a woodshop.
During the CNC process, dadoes are cut into the top, bottom, and rear panels to ensure a tight, secure fit that maximizes the gluing surface and making assembly that much easier. This tower cabinet allows you to create your very own front left or right tower speaker... or even a large format center channel speaker! Three included window braces add structural integrity while consuming as little internal volume as possible.
Additionally, users can mount side-firing a woofer (up to 8" maximum is recommended) for a modern 3-way design. The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Note: Panel dimensions and a 3D SketchUp model are included in the Manuals/Resources section. To open and use the 3D model, you need to download and install a program to unzip the file (7-Zip is free and recommended) and then download and install SketchUp to open the .skp file.
Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 1.16 cubic feet • External dimensions: 34" H x 8" W x 11" D • Internal dimensions: 32-1/2" H x 6-1/2" W x 9-1/2" D • Made in the U.S.A. • Sold individually.
  • BrandParts Express
  • Part Number300-7066
  • UPC844632007286
  • Product CategoryKnock-Down Speaker Cabinets
    (2 Reviews)
  • Weight27.75 lbs.
View similar products to the Parts Express Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
in the Knock-Down Speaker Cabinets product category.
Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet is rated 4.0 out of 5 by 2.
Rated 5 out of 5 by from About what I expectedI found these cabinets easy to assemble. I used the rear panel to hold the braces in place while I applied glue to the side panels. I'll finish gluing on the rear and front panels after I drill vent hole and apply my finish to the front baffle.I didn't have to use a mallet but clamps help to hold things in place while the glue sets up. I used plain yellow wood glue.
Date published: 2014-01-30
Rated 3 out of 5 by from This cabinet is ok..IF you know what you are doing,IF you get ALL corners trued..This product needs some helpful hints or instructions.
Date published: 2013-10-24
I see from another question that I could use my 10" drivers but is the inner volume going to be enough for a 10" driver, one 6.5" mid, and a tweeter? I plan on venting.
Asked by: atoddvr6
This depends on the drivers you decide to use. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-01-06
Are there pre-cut holes with this cabinet
Asked by: lovellw
I am sorry, we do not offer this cabinet with pre cut holes.
Answered by: Chrisf
Date published: 2015-01-05
I am looking for cabinets to replace 2x15 with horns, where can I go, here?
Asked by: Bob3rock
We do offer single 15" 2 way cabinets, but nothing with dual woofers. These will likely have to be custom built.
Date published: 2014-11-18
Can you rotate these 90 degrees to use the 9.5" side as the baffle?
Asked by: Auburn 77 81
Yes, although only one side will have the rounded edges. This wont negatively affect anything, it may just look a bit odd.
access for crossover maintenance
I'm wondering how to provide access to the crossover when using this cabinet without making a mess. I'm looking to avoid exposed screws. Can the bottom be secured effectively on all four sides using pocket screws?
Asked by: aespen
Enclosure rigidity is among the most important aspects of enclosure construction, so I caution against using removable walls (or bottoms) and I recommend keeping all 6 sides rigidly screwed and glued. I also offer these suggestions: 1.) Leave your crossover outside of the enclosure while developing/adjusting your crossover. This practice is made simple by using one of the Bi-wire Terminal Cups, with one terminal set temporarily connected to the tweeter and the other terminal set temporarily connected to the bass drivers. After completion of your crossover, you can mount it inside for better aesthetics. 2. Mount the completed/tested crossover on the enclosure back wall directly behind your largest drivers; this practice typically leaves sufficient access for removing the crossover for maintenance or change (that may never actually be required). 3. another method is to use a terminal cup that is sufficiently large to allow access to the internally-mounted crossover--or even making your own terminal plate by simply cutting a larger terminal cutout and making a MDF cover plate for your terminals or terminal cup.Cheers
Answered by: platoindy
Date published: 2013-09-30
What would the reccomended set be for these cabinets i/e speakes and crossovers ?
Asked by: AVguy
There is not a kit designed around these speaker cabinets at this time.
Answered by: Chrisf
Date published: 2013-10-03
Customer projects that include: Parts Express Knock-Down MDF 1.16 cu. ft. Tower Speaker Cabinet
