300-7060_ALT_0
300-7060_ALT_1
300-7060_ALT_2
300-7060_ALT_3
300-7060_ALT_4
Parts Express Knock-Down MDF 0.04 cu. ft. Micro Bookshelf Speaker Cabinet Pair
Build your own micro bookshelf or satellite speaker with this precision CNC-cut 0.04 cubic foot MDF cabinet.
  • Precision CNC-cut for professional results
  • Acoustically inert 1/2" MDF for low panel resonance
  • Quick and easy to assemble
  • Made in the U.S.A.
300-7060
Weight: 3.85 lbs.
IN STOCK
List Price$39.99
You Save38%
$24.90
Buy 3-up$22.48
Part # 300-7060
Qty:  PR
When it comes to designing desktop computer speakers, surround sound speakers, and micro bookshelf speakers, the hard work has been done for you. With this 0.04 cubic foot speaker cabinet pair, you get CNC-precision cut cabinets without having to own or operate a CNC!
During the manufacturing process, dadoes are cut into the top, bottom, and rear of the side panels to ensure a tight, secure fit, maximizing the gluing surface and making assembly that much easier. The front baffle features roundovers on the sides for a professional look while minimizing diffraction, and the entire cabinet is made of MDF for an acoustically inert effect on speakers.
The end result is a speaker cabinet that assembles in no time flat—all you need are wood clamps, wood glue, and about five minutes; no screws needed.
Note: Panel dimensions and a 3D SketchUp model are included in the Manuals/Resources section. To open and use the 3D model, you need to download and install a program to unzip the file (7-Zip is free and recommended) and then download and install SketchUp to open the .skp file.
Specifications: • Panel thickness: 1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished cabinet volume: 0.04 cubic feet (70 cubic inches) • External dimensions: 6.5" H x 4.5" W x 5" D • Internal dimensions: 5.5" H x 3.5" W x 4." D • Made in the U.S.A.
  • BrandParts Express
  • Part Number300-7060
  • UPC844632006975
  • Product CategoryKnock-Down Speaker Cabinets
  • Unit of MeasurePR
    (6 Reviews)
  • Weight3.85 lbs.
View similar products to the Parts Express Knock-Down MDF 0.04 cu. ft. Micro Bookshelf Speaker Cabinet Pair
in the Knock-Down Speaker Cabinets product category.
Parts Express Knock-Down MDF 0.04 cu. ft. Micro Bookshelf Speaker Cabinet Pair is rated 4.8333 out of 5 by 6.
Rated 5 out of 5 by from Knock down Speaker cabinet is easy to assemble.These speaker cabinets are good quality. Once you assemble them correctly, they glue together with wood glue. No nails are necessary.One needs to hold them in your had for a minute or two after gluing, making sure all edges stay aligned properly.I installed the Fountek FE83 3 inch speaker. Once finished, they work very well with my 2.1 sound system for my TV. The speaking voices are very well defined and music down to about 150 Hertz has a very good sound. This is a low distortion system. I do have a sub woofer with these speakers to fill out the lower frequencies.I normally do not turn on the sub woofer except for music or movies. This system is a bargain at these prices.
Date published: 2015-01-24
Rated 5 out of 5 by from Excellent for small full range speaker projectsThese are my third pair of the tiny little boxes. I have assembled two sets of them as gifts to my grammndaughters. The sound really good matched to the Dayton DTA t-amps. The boxes are pre- cut and go together very quickly and easily. I modify them slightly by adding a removable rear panel. Very surprising sound quality. Works well as p.c. speakers or small surround boxes.
Date published: 2015-01-11
Rated 5 out of 5 by from Time saverSure for the price these can be made cheaper, but c'mon some wood glue and a couple of clamps, add about 5 minutes of your time and they are done for the most part! Everything matched up and fit perfect, I used them to make some computer speakers on a whim and will probably order more
Date published: 2014-02-10
Rated 4 out of 5 by from Good CabinetsI was wanting to add tweeters to my old speakers but did not want to do a lot of work, so I thought I would give these a try and put the tweeters in separate cabinets. Man this was just what the DR. ordered !These are not flimsy cabinets ,very easy to build and have a good price.PE had the tweeters and speaker wire terminals to finish the job.
Date published: 2013-11-25
Rated 5 out of 5 by from easy peasyThis is the second set of these knock-downs I have purchased. Great quality and they go together perfect. Highly recommend.
Date published: 2013-07-19
Rated 5 out of 5 by from PerfectEasy to build!! The pcs fit together perfectly!! Glue and nails is all you need to build them.
Date published: 2013-01-11
  • 2015-02-28T06:21CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_300-7060, PRD, sort_mostRecent
If i used the dayton nd91-8 in this enclosure, would one peerless 3.5 inch passive radiator be enough? Matt said it would tune it to about 65hz. If i used 2 passives instead of one, would it tune it even lower? Thanks! I really appreciate all this help!
Asked by: Chris Colburn
65 Hz is about all you will be able to get out of these drivers. Using two passives will only tune higher unfortunately.
Date published: 2015-02-25
You recommended a peerless passive radiator in this enclosure with the dayton nd91-8. What radiator would you recommend? Do i still use the 1 inch diameter by 4 inch long port? Your help has been awesome. Thank you so much!
The passive radiator replaces the port, you will not use both. The Peerless I am referring to is below.http://www.parts-express.com/peerless-830878-3-1-2-passive-radiator--264-1060
Date published: 2015-02-24
I asked about the dayton nd91-8 in the .04 cube knock down micro cabinets with a 1 inch diameter round port 4 inches long. Is there any way i could get it tuned lower than 110hz? Different port maybe? Should i try some poly fill?
There are two options for a lower tun in that enclosure. If you wanted to stick with a standard vented design you would have to use an external 1" diameter port because it would have to be 12" long in order to tune the enclosure to about 65 Hz. You could also use one of the Peerless passive radiators with no weight added for a similar tuning frequency. This was modeled with average poly fill, just enough to lightly fill the enclosure.
Hi, I was wondering if the Dayton nd-91 8 ohm would be a good driver in this box with a 1 inch diameter round port that is 4 inches long? Thanks!
Asked by: ChrisColburn
This will work but will have a relatively high tuning frequency around 110 Hz. This will provide a bit of a natural bass boost so it will probably sound pretty good, although it will not play much lower than about 90 Hz.
Date published: 2015-02-23
Can a third enclosure be purchased along with a pair? I'd need three enclosures for a project I have in mind.
Asked by: Ooops
Unfortunately these are only sold as pairs.
Date published: 2014-10-24
can i fit 1 5.25" speak in there?
Asked by: speaker_guy
The baffle is only 4" wide on this cabinet, a 5-1/4" speaker will not fit.
Date published: 2014-10-04
  • 2015-02-27T07:29CST
  • co_hasquestionsanswers, tq_13
  • loc_en_US, sid_300-7060, PRD, sort_recentQuestionsFirst
Customer projects that include: Parts Express Knock-Down MDF 0.04 cu. ft. Micro Bookshelf Speaker Cabinet Pair
