180-995_ALT_0
180-995_ALT_1
180-995_ALT_2
180-995_ALT_3
Parts Express HDMI Audio Extractor with Toslink and L&R Audio
Brand:|Part # 180-995
More television manufacturers are omitting RCA analog audio outputs, leaving owners of legacy stereo equipment in the lurch. The solution is this HDMI audio extractor that extracts the audio out of your HDMI signal, while allowing the full signal to pass through.
List Price$48.99
You Save23%
$37.50
Buy 4+$35.63
Part # 180-995
  • Pulls the audio signal from HDMI source and converts to analog and digital signals to use with older audio equipment
  • Use older audio systems with your new TV
  • Built-in EDID emulator for 2-channel and 5.1-channel audio
  • No loss in video resolution
Adding equipment to your home theater system is difficult when devices don't share the same technology. It is often necessary to find a work-around such as connecting an HDMI to the television and running a Toslink cable back to the AV receiver. This can be a difficult and costly exercise, and you might not get the audio signal that you want.
An HDMI Audio Extractor allows you to tap into the HDMI signal and pull out the audio you need for your sound system. A built-in EDID emulator tells your source device to generate a 2-channel or 5.1-channel audio signal. Installation is easy; after connecting the extractor with HDMI cables, run a Toslink cable to the amplifier digital input, or stereo audio cable to the analog input and you can enjoy your favorite movies and programs through your existing audio equipment.
Specifications: • HDMI video support: Up to 1080p + 3D • Power Requirements: 5 VDC, 1A • Weight: 0.3 lbs. • Dimensions: 3.33" H x 2.43" W x 0.83" D.
Note: The RCA analog output will not work if the incoming audio is multi-channel audio (>2CH). The SPDIF does not support Dolby Digital Plus and PCM 5.1CH and beyond.
  • BrandParts Express
  • Part Number180-995
  • UPC848864007304
  • Product CategoryDigital Audio/Video Converters
    (9 Reviews)
  • Weight0.6173 lbs.
View similar products to the Parts Express HDMI Audio Extractor with Toslink and L&R Audio
in the Digital Audio/Video Converters product category.
