320-353_ALT_0
Parts Express BT-1A Bluetooth Receiver Module for Wireless Reception of Bluetooth Audio Signals
Brand:|Model: BT-1A|Part # 320-353
The BT-1A Bluetooth module adds a Bluetooth wireless audio receiver to nearly any device. Great for connecting the Bluetooth audio output of an iPad, tablet computer, or smartphone to your computer, receiver, or even your subwoofer, wirelessly.
List Price$29.99
You Save38%
$18.70
Buy 4+$17.90
Part # 320-353
  • Add a Bluetooth audio receiver to nearly any amplifier
  • Class 2 range of up to 15 meters (49.2 feet)
  • 16-bit A2DP support for true stereo output
  • On-board power and audio jacks
  • Includes connection cables
  • Voice prompts for device pairing
  • Bluetooth v1.2 compliant
The BT-1A module builds upon the success of the orignal BT-1 Bluetooth audio receiver, and improves upon it by moving the power and audio connections on-board (2.5 x 1 mm power jack and stereo 3.5 mm audio jack), reducing the overall size of the module, and adding voice prompts for pairing and connection instructions.
The BT-1A is designed to integrate wireless Bluetooth audio from smartphones, tablets, or laptops into speakers and subwoofers, car audio applications, and remote wireless amplifiers. Additionally, this module may be used to create a wireless link between a Bluetooth source and a traditional amplifier, receiver, preamplifier, or mixer.
Features of this Bluetooth v1.2 compliant receiver module include a small form factor, a Class 2 range of up to 15 meters (49.2 feet), and 16-bit A2DP support for true stereo output. A USB A-Male to 2.5 x 1 mm power plug cable and a stereo 3.5 mm male plug to 3.5 mm jack extension cable are included with the module for quick connection and use. The USB A-Male plug is used as a power connection that uses 5 VDC off of the USB bus from a computer or powered USB hub.
Specifications: • Supply voltage: 3.3 to 5.0 VDC • Supply current: 50 mA • Operating frequency: 2.4 to 2.483 GHz • Bluetooth specification: v1.2 • Output power class: Class 2 • Receiver sensitivity: -80 dBm • Output level: 1V RMS • Output impedance: 1k ohm • Frequency response: 20-20,000 Hz (-3 dB) • Sampling: 44.1 kHz, 16-bit • Signal-to-noise ratio: 70 dB • THD: < 0.1% @ 1 kHz • Dynamic range: 85 dB • Channel separation: 65 dB • PCB dimensions: 3/4" W x 2-1/2" L • Includes 12" USB power cable and 18" stereo male to stereo female audio cable • Audio output cable length: 18".
Note: This device only receives stereo Bluetooth audio. The USB cable included is only for powering the BT-1A. This device does not transmit a Bluetooth signal, and does not convert the digital USB audio output to analog. Ground loops can occur when using a grounded (3-prong plug) computer as the power source. Please see the Related Items section for the Axxess 3.5 mm ground loop isolator to solve this issue if it occurs.
  • BrandParts Express
  • ModelBT-1A
  • Part Number320-353
  • UPC844632006951
  • Product CategoryBluetooth Receivers & Transmitters
    (43 Reviews)
  • Weight0.1 lbs.
View similar products to the Parts Express BT-1A Bluetooth Receiver Module for Wireless Reception of Bluetooth Audio Signals
in the Bluetooth Receivers & Transmitters product category.
