CLEARANCE
Panavise 105108B Speaker Stud Mount Black
Brand:|Model: 105108B|Part # 240-726
These wall/ceiling STUD speaker mounts from Panavise feature a "tilt, turn, and rotate" design to allow versatile adjustment of bookshelf size loudspeakers. Rugged all metal construction is rust and corrosion resistant.
List Price$22.99
Regular Price$20.49
You Save11%
Sale Price
$18.29
Part # 240-726
  • Versitle and easy to use
  • Rust and corrosion resistant
  • Fully adjustable
  • A complete mounting system
  • Mounting instructions included
These wall/ceiling STUD speaker mounts from Panavise feature a "tilt, turn, and rotate" design to allow versatile adjustment of bookshelf size loudspeakers. Rugged all metal construction is rust and corrosion resistant. Includes hardware and complete mounting instructions. Rated to hold speakers up to 8 lbs. Includes two different sized mounting studs (1/4-20 and 10-32). Your choice of white or black. Sold individually. Made in the U.S.A.
  • BrandPanavise
  • Model105108B
  • Part Number240-726
  • UPC729315511086
  • Product CategorySpeaker Wall Mounts
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Panavise 105108B Speaker Stud Mount Black
in the Speaker Wall Mounts product category.
Panavise 105108B Speaker Stud Mount Black is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Good product for the moneyI'm no expert at speaker mounts, and as a consequence I don't know what options are out there that may look better. That said, the installation is solid and the pivot lets you angle the speaker at just about any direction you need. I would like to see an integrated wall plate with this product so you could run the speaker wire through an outlet box and mount it to the outlet box too. (In order to run wire through my outside wall with insulation, I would need to cut a hole the size of an outlet box just to have a chance of passing it through the floor, however you you will end up with a hole that has to be patched and you can't use that hole for this mount anymore). If you're lucky enough to have the ability to run a wire through a 1/4" hole, good for you.I ran my wire though the floor coming out just above the baseboard, using vinyl cable tube from Lowes. I Drilled a hole through the floor using a 1/4" x 18" long drill bit.One negative thing is that the instructions suck. There are some extra parts that come in the kit that are needed but not pointed out or explained. The other is that the supplied screws are silver and stick out from the mount like a sore thumb. Again, I don't know if there's something better and more attractive for the same price.
Date published: 2008-03-14
  • 2016-02-11T06:53CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_240-726, PRD, sort_mostRecent
