BUYOUT
269-011_ALT_1
269-011_ALT_0
Panasonic SUPS135-11 Speaker Terminal Plate with Tweeter and Mid High Pass
Brand:|Model: SUPS135-11|Part # 269-011
Save over 50% off, and up to 60% off, the original retail price on this Panasonic terminal plate with tweeter and midrange high pass, through Parts Express exclusive factory buyout.
$2.00
Buy 10+$1.75
Part # 269-011
  • Large spring-loaded speaker wire inputs
  • Built on dual high-pass crossovers for a tweeter and midrange
  • 1.2 µF and 100 µF capacitors
  • 15Ω, 5 watt resistor
Panasonic built the SUPS135-11 speaker wire terminal plate with crossover using a 100 µF series capacitor to create a 6 dB/octave, 200 Hz midrange high-pass (assuming an 8 ohm midrange), and a 1.2 µF series capacitor to create a 6 dB/octave, 5,500 Hz tweeter high pass (assuming an 8 ohm tweeter and accounting for the series 15 ohm resistor). The series 15 ohm resistor pads the tweeter's response by almost 6 dB for level matching to the midrange.
Dimensions: Overall: 2-9/16" H x 2-9/16" W, Cutout: 2-1/4"dia.
Save over 50% off, and up to 60% off, the original retail price through this Parts Express exclusive factory buyout. Hurry, quantities are limited!
  • Crossover TypeHigh Pass
  • ConfigurationIncludes Connector Dish
  • BrandFactory Buyouts
  • ModelSUPS135-11
  • Part Number269-011
  • UPC848864012643
  • Product CategoryAssembled Passive Crossovers
    (3 Reviews)
  • Weight0.1500 lbs.
View similar products to the Panasonic SUPS135-11 Speaker Terminal Plate with Tweeter and Mid High Pass
in the Assembled Passive Crossovers product category.
Panasonic SUPS135-11 Speaker Terminal Plate with Tweeter and Mid High Pass is rated 4.0 out of 5 by 3.
Rated 4 out of 5 by from Good for mei bought a pair of these and all of my reviews so far have been a solid 5 stars. These terminal plates with the high pass for your tweeter and mid are great but when wanting to hook up a woofer, gotta find the leads to the circuit board off of the terminals themselves and solder wires off of that for your woofer to receive a full range signal or patch a second low pass filter for a solid 3-way crossover network. also i find it odd that the black wire is positive and yellow for negative for your TWEETER. other than that, fantastic buy if your planning on bi-amplifying your speakers or need a fresh start on a crossover, these work very well with the GRS 5SBM-8 midrange.
Date published: 2015-08-10
Rated 3 out of 5 by from good enoughI bought these to add to my speakers with that had no crossovers. There are no directions for connecting them so I just used trial and error. Seems like pretty old stock but they are working and the price was right. I still don't know if they are correctly wired but so far so good.
Date published: 2015-05-31
Rated 5 out of 5 by from Always great serviceParts Express is always quick on shipping my parts, and I have never had a problem with any part being defective.
Date published: 2015-01-15
  • 2016-02-10T06:40CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_269-011, PRD, sort_mostRecent
Thinking of using these for a surround sound speaker build. Can these handle 50-100watts of power?
Asked by: Bcboyz86
Yes these should handle that without a problem.
Date published: 2015-08-05
How do I wire this for full range on the mid (hivi b3n) and just cross the tweeter(cheap goldwood) at 5k?   I see conflicting answers on the wiring in the q and a section.   I don't wanna  blow my components from a wrong wire!
Asked by: Ben24
The black and yellow wires are for the tweeter, black being positive. The red and gray are for the mid, red being positive.
Date published: 2015-08-18
With the wiring on the back of the crossover, which color goes to which speaker?
Asked by: Antipodean
I hoped for a schmatic or picture to described best where it is suggested where to wire the speakers in a 2 way cabinet. I'm using this part to use this cabinet for guitars and bass with the 2 way, the Pyle 1000,2 10" Emenance 2 Pyle bullet horns. Help?
Asked by: jsfmidig
Date published: 2015-04-14
Forgive my naivete, but how would one bypass the capacitor for a full-range woofer? Thanks!
Asked by: SeanMcCauley
You would just want to connect to the main input leads.
Answered by: RobTaylor
Date published: 2015-04-17
Can I use this with GRS 6PF-8 6-1/2" Paper Cone Foam Surround Woofer and Goldwood GT-510 1" Soft Dome Tweeter for home theater?
Asked by: keepserenity
Yes this will work with those drivers, but if you do not want to high-pass the woofer you will have to bylass the 100 uF capacitor in order to send it a full range signal.
Date published: 2015-02-06
  • 2016-02-10T07:23CST
  • co_hasquestionsanswers, tq_18
  • loc_en_US, sid_269-011, PRD, sort_recentQuestionsFirst
