BUYOUT
299-681_ALT_0
299-681_ALT_1
299-681_ALT_2
Panasonic EAB834R LCD TV Right Side Two-Way Speaker
Brand:|Model: EAB834R|Part # 299-681
Save over 50% off this two-way LCD TV speaker module (that makes a very interesting looking bookshelf speaker) through this Parts Express exclusive buyout!
List Price$10.00
Regular Price$4.90
You Save49%
Sale Price
$2.50
Part # 299-681
  • Designed as drop-in speaker replacements for Panasonic LCD TVs
  • Makes for an interesting industrial speaker, great for art projects
  • Bi-wired design for easy custom crossover implementation
  • Front mounted 2" speaker and 3" rear mounted speaker
  • Panasonic manufacturer part number EAB834R
Panasonic designed the EAB834R right side, self-contained, L-shaped two-way speaker for their 32" TX-32DLX52 LCD TV. This speaker also drops into Panasonic TC26LE55, TC26LX50, and TC32LX50 LCD TVs for quick, easy replacement.
A front-facing 2", full-range driver (with paper cone and cloth surround) is combined with a rear-facing 3" midbass (with paper cone and rubber surround) to create a compact satellite speaker that integrates well with subwoofers.
Speaker connection is provided through a four-pin connector. The red and brown wires connect to the 2" driver, while the red and black wires connect to the 3" driver. Each speaker is loaded into a sub-section of the cabinet: the 2" speaker section is sealed, whereas the 3" speaker section is ported and tuned to 80 Hz.
2" driver specifications (measured in cabinet): • Power handling: 10 watts RMS/20 watts max • Impedance: 8 ohms • Re: 6.76 ohms • Le: 0.38 mH • Frequency response: 300-16,000 Hz • Fs: 314 Hz • SPL: 85 dB 1W/1m • Qms: 4.76 • Qes: 2.81 • Qts: 1.76.
3" driver specifications (measured in cabinet): • Power handling: 15 watts RMS/30 watts max • Impedance: 6 ohms • Re: 4.75 ohms • Le: 0.83 mH • Frequency response (based on cabinet tuning): 80-4,000 Hz • Fs: 172 Hz • SPL: 85 dB 1W/1m • Qms: 4.05 • Qes: 1.91 • Qts: 1.30.
Cabinet dimensions: 8-1/4" H x 4-7/8" W x 2-1/2" D minimum (4-1/8" D maximum).
Save over 50% off the discounted retail price through this Parts Express exclusive buyout. Hurry, supplies are limited!
  • Input Rating6 ohm,8 ohm
  • Special FeaturesWater Resistant,Speaker Bar
  • Woofer Diameter3"
  • Configuration2-way
  • ColorBlack
  • BrandFactory Buyouts
  • ModelEAB834R
  • Part Number299-681
  • UPC848864013039
  • Product CategorySpeaker Modules
  • Weight1.7500 lbs.
View similar products to the Panasonic EAB834R LCD TV Right Side Two-Way Speaker
in the Speaker Modules product category.
