PA Knock-Down Trapezoid Plywood Speaker Cabinet for 15" Driver
Brand:|Part # 245-326
You can build a pro-quality trap PA cabinet, even if you don't own a table saw! This 15" knock-down kit's clean, accurate, CNC dado joints guarantee fast, easy, and rugged construction that results in a solid cabinet with a minimum of fiddly bracing.
  • Easily assembled plywood panels with CNC-dadoed joints
  • Trapezoid shape facilitates arraying multiple speakers
  • 14" cut-out fits most 15" speakers
  • Wood screws included
  • Easy-to-follow instructions
  • For portable use or permanent installations
  • You provide the labor, wood glue, and components!
You can build a pro-quality trap PA cabinet, even if you don't own a table saw! This 15" knock-down kit's clean, accurate, CNC dado joints guarantee fast, easy, and rugged construction that results in a solid cabinet with a minimum of fiddly bracing. Pre-cut hole accommodates most 15" drivers. Includes CNC-cut plywood knock-down panels, optional front protection grill supports, wood screws, and assembly instructions. The high quality low-loss wood means more of the power that drives the speaker will turn into sound and less will be used to shake, rattle, or resonate the cabinet. Exceptionally smooth, dense, strong, and virtually non-resonant 3/4" plywood. Sold individually.
Specifications: • Internal volume: 2.75 cu. ft. • Dimensions: 30-1/2" H x 19" W (front), 9-3/4" (rear) x 17-1/8" D.
  • BrandParts Express
  • Part Number245-326
  • UPC844632089633
  • Product CategoryKnock-Down Flat-Pack Speaker Cabinets
    (9 Reviews)
  • Weight30.1 lbs.
Videos
