245-326_ALT_0
245-326_ALT_1
PA Knock-Down Trapezoid Dragon Ply Speaker Cabinet for 15" Driver
Product Video
You can build a pro-quality trap PA cabinet, even if you don't own a table saw! This 15" knock-down kit's clean, accurate, CNC dado joints guarantee fast, easy, and rugged construction that results in a solid cabinet with a minimum of fiddly bracing.
  • Easily assembled Dragon Ply panels with CNC-dadoed joints
  • Trapezoid shape facilitates arraying multiple speakers
  • 14" cut-out fits most 15" speakers
  • Wood screws included
  • Easy-to-follow instructions
  • For portable use or permanent installations
  • You provide the labor, wood glue, and components!
245-326
Weight: 30.1 lbs.
IN STOCK
List Price$124.99
You Save24%
$94.90
Buy 4-up$89.80
Part # 245-326
You can build a pro-quality trap PA cabinet, even if you don't own a table saw! This 15" knock-down kit's clean, accurate, CNC dado joints guarantee fast, easy, and rugged construction that results in a solid cabinet with a minimum of fiddly bracing. Pre-cut hole accommodates most 15" drivers. Includes CNC-cut Dragon Ply knock-down panels, optional front protection grill supports, wood screws, and assembly instructions. The high quality low-loss wood means more of the power that drives the speaker will turn into sound and less will be used to shake, rattle, or resonate the cabinet. Exceptionally smooth, dense, strong, and virtually non-resonant 3/4" Dragon Ply.
Specifications: • Internal volume: 2.75 cu. ft. • Dimensions: 30-1/2" H x 19" W (front), 9-3/4" (rear) x 17-1/8" D.
  • BrandParts Express
  • Part Number245-326
  • UPC844632089633
  • Product CategoryKnock-Down Speaker Cabinets
    (9 Reviews)
  • Weight30.1 lbs.
View similar products to the PA Knock-Down Trapezoid Dragon Ply Speaker Cabinet for 15" Driver
in the Knock-Down Speaker Cabinets product category.
PA Knock-Down Trapezoid Dragon Ply Speaker Cabinet for 15" Driver is rated 4.1111 out of 5 by 9.
Rated 4 out of 5 by from Great for the PriceI found the 11 ply birch decent quality. I have used better but at a price.I built mine as a coaxial Mid Hi pak, 15" and a 1.4 exit horn, so I cut the over all height by 8 inches. Use a lot of wood glue, and definitely seal the inside with RTV, about 1 tube per cabinet. Also I used the pieces provided for mounting a grill to brace the baffle on the inside. Very solid. Use a lot of putty, sand well, and you end up with a nice box. Take your time, do things in stages. Let glue and RTV cure. I also used a router on the corners. When you drill holes, go slowly. If you push too hard using a hole saw, you could remove some of the ply. Go Slow. I will try and add some photos later. The one thing I really didn't care for was the gaps left between the baffle and sides top/bottom. Had to use a fair amount of putty to seal those up.
Date published: 2014-08-16
Rated 5 out of 5 by from Very simple assemblyI needed some quick and sturdy boxes for some JBL D-130 woofers and these did the trick quite nicely. I finished them with black "Restore" deck paint after rounding off all the edges with a router and 80 grit sand paper. My main advise is to cut your holes for your horn and ports on the baffle before assembly. I only wish that Parts Express offered a pre-formed grill that fit these cabinets with no modifications required.
Date published: 2013-05-24
Rated 5 out of 5 by from Not a bad set of boxes.Been doing sound for a long time and if you load these with the right components these boxes rock. Just recently took out a couple of 22xt peavey drivers and newer black widow 15's out of an old sp3 cabinet that was finally falling apart and recycled everything into these newer and much lighter boxes. Ended up having a nice pair of pretty much brand new speakers. Using peavey sp2g crossovers which work fairly well with these boxes. Instead of using port tubes I cut slots for handles that act as porting. Overall was a quick and easy project to complete. Also, if you are using heavy duty speakers that move a lot of air you MUST seal every joint in these boxes with silicon and use a generous amount of glue on all cuts and tabs. The only suggestion I would make is a better system for grill covers to be mounted. These boxes are made for a P.A. not home stereo so a steel mesh or expanded metal front should be used not grill cloth.
Date published: 2013-04-12
Rated 4 out of 5 by from Rumble FilldirtA great choice for me.Pretty good Birch with very few voids visible on the edges.Cut edges require a little sanding but fit together well after some TLC.Each box eats up a whole pint of wood glue and a whole tube of caulk, but is very leak free and strong in the end.I added some 1" oak dowel rods in 2 places as bracing and after that the cabs were rock solid.They ring like a bell when I rap on them.I also doubled up the baffle as I used these for 12" woofers and had to make a smaller speaker hole.Adding a layer of 3/4 Baltic Birch to the baffle made the boxes very stiff.They ate up a gallon of texture paint and a quart of oil based primer, but now they look awesome.I recommend these to anyone who doesn't have access to a complete wood shop, or as anyone's first DIY project.These boxes rock with 12's, I can't imagine them with 15's installed.Just for the cost of wood, these are a good deal.Very satisfied,Rumble
Date published: 2012-09-05
Rated 2 out of 5 by from Needs better plywoodThe cabinet enclosure volume is too little for most 15" drivers, if you correctly subtract the amount of space the driver itself occupies inside. So I put in 4 12" as two pairs of clamshelled isobaric pairs. And I added a thick fromt removable baffle board. You can get decent plastic or metal cabinet corners for 15 degreee trapezoids, and they make it look a lot more finished. But in the end, this kit is screaming desperately to be made of better plywood. I had no idea they made plywood this cheap.
Date published: 2012-05-02
Rated 4 out of 5 by from Good concept that needs more thought in it's executionThis is not just some kit that you can slap together and expect good results. First, you need the right tools. You're going to need to take your time with it. After getting your holes cut for ports, mid, tweeter, pocket handles and terminal cup, which could take anywhere from 1-3 hours, it will take about an hour to assemble. My advice from actual experience with this product is to assemble the cabinet as directed, with one exception. Don't glue the top of the cabinet on until you are finished loading your drivers, crossover network and have given it a good test run. This made my job so much easier because I had free access to the inside walls of the enclosure.After I was all set up and ready to go I cued up some music and set the mixer gain at a moderate level and punched up the bass. Vibration. I heard an obnoxious rattling that just kind of droned. I lowered the volume. Even at low volume there was undesirable noise emminating from the cabinet. After some investigation I discovered that the front baffle was flexing between the woofer and midrange. This is my main reason for advising to not glue on the top panel. After my little test run I simply removed the top and installed a T-brace with the top of the T pushing against the spot that was rattling. It took all of 5 minutes to solve the problem. I think including a brace in the kit would improve customer satisfation since some people might think it's not so great a product because they don't have the experience to deal with a problem like this.It is a strong, lightweight box when finished and I am very please with it's performance now that the bugs are worked out.
Date published: 2012-02-08
SHOULD I USE A HORIZONTAL BRASE/VOL DECREASER TO INHANCE THE BOX FOR A 15" PIONEER 40-13A/XL WOOF? I USE 2" AIR CON. DUCT BOARD GLUED INSIDE OF THE WOOF AND MID SECTIONS OF MY ENCLOSERS. 2.75 TO MUCH ? I USE A LARGE PORT 1.4 CUFT NOW FOR WOOF IT ROCKS.
Asked by: DAVID MAKAN
Date published: 2014-08-28
MY MIDRANGE IS 9 INCH OD AND MY TWEETER IS 4 INCH SQUARE WILL THIS FIT INTO THE FRONT WITH MY 15.5 INCH OD WOOFER ? AND HOW MUCH SPACING CAN I PUT IN BETWEEN EACH ? WOOF TO MID MID TO TWEET
Planning on buying PA380-8 woofs and D250P-8 drivers (Dayton). I have 2 4" dia. by 6" long port tubes. I would like to single port these. Port tube length? And with a #260-140 2k xover, what would the impedence of the cab be? Will this work? Thx!
Asked by: dirkmeister
I would recommend cutting the 4" port to 3" long for a tuning frequency of 44 Hz. With those drivers, the overall impedance load will be 8 ohms.
Date published: 2014-06-30
There was a 12' version that got great reviews also, what happened to that? I looking for a smaller cabinet to play with field coll and Coaxial speakers. Are the 12" version ever coming back? Any chance for a smaller size maybe 8"?
Asked by: MantisLover
Unfortunately the 12" version was discontinued. Our product line is always expanding so there is always a possibility of more enclosure types in the future.
Date published: 2014-04-07
Would this be suitable for a home 3 way system using Dayton classic 15" and 2- 6.5" Dayton classic for midrange and maybe Dayton silk dome tweeters?
Asked by: Capt Navarre
Yes these can be used to any application you would like. With 2.75 cubic feet of volume I would recommend keeping it sealed with most 15" drivers for the smoothest response.
Date published: 2013-11-18
Where do you get corners for a Trapezoid cabinet?
Asked by: G. G.
You can try these out. http://www.parts-express.com/wizards/searchResults.cfm?srchExt=Cat&srchCat=136. Metal can be reformed with the right technique.
Answered by: Zobadar
Date published: 2012-07-31
Videos
Customer projects that include: PA Knock-Down Trapezoid Dragon Ply Speaker Cabinet for 15" Driver
