P3 Platinum 4 AWG Power Terminal Pair
Brand:|Part # 263-685
Serious power requires a serious connector, and the P3 ring terminals get the job done with style. 5/16" ring size.
List Price$17.95
You Save50%
$8.89
Buy 4+$7.96
Part # 263-685
Serious power requires a serious connector, and the P3 ring terminals get the job done with style. Solid construction with a beautiful simulated platinum finish at a price that will get you hooked up. Set-screw style wire mount. 5/16" ring size, great for use with the P3 tri-oval battery terminals. Sold in pairs, color stripe indicates polarity. Dimensions: Overall length: 2.24", Overall diameter: .63", Max wire diameter: .35", Max insulation diameter: .44".
  • Connector TypeRing
  • Wire Gauge4 AWG
  • Terminal / Stud Size5/16"
  • BrandP3 Car Audio
  • Part Number263-685
  • UPC844632016745
  • Product CategoryPower Cable Ring Terminals
    (6 Reviews)
  • Weight0.24 lbs.
View similar products to the P3 Platinum 4 AWG Power Terminal Pair
in the Power Cable Ring Terminals product category.
P3 Platinum 4 AWG Power Terminal Pair is rated 4.1667 out of 5 by 6.
Rated 5 out of 5 by from Performance over PriceI brought these knowing they were the cheapest and not the most expensive ones. But wen I got them I was surprised at the quality of these connectors. They are heavy, very durable and the set screw holds very tight to my 4 gauge wires and never once did any screw get stripped like on my older more expensive ones.
Date published: 2012-08-12
Rated 3 out of 5 by from Great for battery terminalToo large for amp connectors but work great on battery
Date published: 2009-07-22
Rated 3 out of 5 by from Cheap Cost - Cheap QualitySimple parts. Decent quality. Not streetwires, but doesn't require a private loan either. Allen head set screws are a little too small for the wrench size they were intended for. Small bored inset covers insulation so it looks clean.
Date published: 2009-06-15
Rated 4 out of 5 by from good connector - does not fit stock Scion batterygood product, however the connector is to thick for a scion stock battery mounting bolt. also recommend to put shrink tubing or elct tape around connector
Date published: 2009-05-18
Rated 5 out of 5 by from good stuffnice high quality product works very well
Date published: 2009-03-07
Rated 5 out of 5 by from ExcellentVERY solid contstruction/ solid set screws. Does not seem like it will deteriorate quickly.I needed to increase the diameter of the ring, and I could clearly see how solid these terminals are made.
Date published: 2007-11-24
  • 2016-02-09T06:33CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_263-685, PRD, sort_mostRecent
