NuVo Wireless NV-GW100 Wireless Access Point
Brand:|Model: NV-GW100|Part # 301-196
NuVo Wireless is the ultimate solution to adding multi-room, multi-zone audio to existing homes. It all begins with the GW100 Gateway, the center of your new music-only wi-fi network.
$199.00
Part # 301-196
  • Connects to your existing home network router
  • Establishes a music-only wi-fi network
  • Dual Band Transmission prevents music drop-out
NuVo's new wireless audio system makes multi-room, multi-zone audio distribution easy to install and a pleasure to use. The heart of the system is the GW100 Gateway, which connects to your home network through your router and establishes a music-only wi-fi network for the other NuVo Wireless devices. Then, add zone players for anywhere you need music.
Control is extremely user-friendly through apps for Apple and Android devices. You'll have complete control over audio in every zone and access to all the music stored on your home network. In addition, you'll be able to stream music from Pandora, Rhapsody, TuneIn, and SiriusXM (subscription fees may apply).
For a demonstration of the NuVo Wireless Control App, click here!
The GW100 Gateway allows your zone amplifiers to wirelessly communicate with each other and your home network using the modern 802.11n wi-fi protocol. The Gateway utilizes both 2.4 and 5.6 Ghz bands concurrently to eliminate interruptions to your music. In "Party Mode", music is kept perfectly in sync, all over the house. Because it establishes a separate wireless network from your existing wi-fi, the GW100 won't slow down your internet connection, either.
Specifications: • LAN connection: 5 LAN - RJ45 - 10/100/100 Mbps • Wireless connection: 2 TX x 2 RX MIMO, IEEE 802.11a/b/g/n • Wireless data rate: Up to 300 Mbps • Dimensions: 5.24" D x 6.95" W x 1.29" H • Weight: 0.5 lbs. • Power: 12 VDC, 1A, adapter included.
  • BrandNuVo
  • ModelNV-GW100
  • Part Number301-196
  • UPC701963853084
  • Product CategoryAudio Distribution Systems
  • Weight2.05 lbs.
View similar products to the NuVo Wireless NV-GW100 Wireless Access Point
in the Audio Distribution Systems product category.
