NuVo NV-RVZA-F50S Renovia Stand Alone Power Line 50W Amp
Brand:|Model: NV-RVZA F50S|Part # 301-167
Renovia 50 watt power line amplifier provides inconspicuous and non-disruptive installation and 25 watts of music power per channel in any zone with no electrician needed.
  • Whole Home Audio in up to 8 different rooms
  • Quick, simple installation for a reliable retrofit solution
  • Designed for discreet placement, for a system that is practically invisible
  • 25 watts of music power per channel
  • Operates on line voltage via a detachable power cord, no electrician needed
NuVo’s retrofit solution is the ultimate in flexibility and audio freedom. Combining reliable technology with an unprecedented simplicity, Renovia is a whole home audio system that promises sophisticated sound incorporated almost invisibly into a home’s architecture, without a disruptive installation. Using the home’s existing power lines to distribute audio to up to 8 zones, each Renovia system is comprised of a Source Hub and either an unobtrusive in-wall or an easily concealed freestanding Zone Amplifier. The Source Hub, complete with a built-in dual AM/FM/SIRIUS-Ready tuner, centralizes the system’s six audio sources and can be easily stored out of sight. The system works seamlessly with an extensive selection of sources, including legacy devices and NuVo’s Music Port for access to a whole world of music, as well as Renovia’s own NuVoDock for iPod. Managing the system from a variety of NuVo’s attractive control options is intuitive and uncomplicated. The NV-RVZA-F50S operates on line voltage via a detachable power cord, no electrician needed.
Specifications: • Input power: 100-240VAC 50/60Hz, 15 watts • Input: NuVoNet control pad RJ45 • Line input: 3.5mm stereo jack • Output: Stereo speaker output via screw terminals • Headphone/line output: 3.5mm stereo jack • Impedance: 8 ohm • Power: 2 x 25 watts, 1% THD @ 8 ohms • Frequency response: 27 – 19,000 Hz • Dimensions: 1-7/8" H x 5-7/8" W x 5-7/8" D.
  • BrandNuVo
  • ModelNV-RVZA F50S
  • Part Number301-167
  • UPC701963852957
  • Product CategoryAudio Distribution System Acc.
  • Weight1.55 lbs.
View similar products to the NuVo NV-RVZA-F50S Renovia Stand Alone Power Line 50W Amp
in the Audio Distribution System Acc. product category.
