NTE 54-645-A SPST Round Hole Square Bezel Illuminated Rocker Switch with Amber LED
Brand:|Model: 54-645-A|Part # 060-926
Perfect for automotive or any other 12 VDC project, this switch installs with a clean look and a round hole means easy mounting. LED illumination enables quick switch location in the dark.
- Order Soon - Only 3 Left In Stock
$4.25
Buy 4+$4.09
Part # 060-926
  • Illuminates amber when 12 VDC is applied
  • SPST action for use as an on-off switch
  • Great for automotive use
This round hole, square bezel SPST rocker switch from NTE features always-on 12 VDC illumination (voltage dropping resistor built in) to locate the switch quickly in the dark.
Installation couldn't be easier, simply drill a hole, connect switched +12 VDC to pin 2, ground to the gold pin 3, and your circuit to the pin 1, and you have an illuminated on-off switch. A toothed locking nut holds the switch in place on a variety of materials.
Specifications: • Current rating: 12 VDC, 20A • Insulation resistance: 100 mega ohms (minimum) • Dielectric strength: 1500 VRMS (minimum) • Temperature rating: -13° to 185°F (-25° to +85°C) • Electrical life: 6,000 cycles (maintained), 100,000 cycles (minimum) • Mechanical life: 100,000 cycles (minimum) • Terminal type: 0.187" tab Q.C. • Mounting hole: 0.80" x 0.87" (44.04 x 20.2 mm) • Dimensions: 0.91" W x 1.11" H.
  • CircuitSPST
  • Contact Rating @ Voltage20A 12 VDC
  • IlluminationIlluminated
  • BrandNTE
  • Model54-645-A
  • Part Number060-926
  • UPC768249290841
  • Product CategoryRocker Switches
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the NTE 54-645-A SPST Round Hole Square Bezel Illuminated Rocker Switch with Amber LED
in the Rocker Switches product category.
