Buyout Special
269-605_ALT_0
269-605_ALT_1
NHT M2.3 Speaker Wire Terminal Plate with 3-Way Crossover 150/100 Hz 1,700/3,400 Hz
Save big on crossover components through this Parts Express exclusive factory buyout. This terminal plate with 3-way passive crossover was designed by NHT. The inductors on this crossover alone would sell for over $20!
  • NHT designed three-way crossover with dual woofer output
  • Save big on crossover components
  • Common component values
269-605
Weight: 1.4 lbs.
NHT designed this binding post style speaker wire terminal plate (that accepts banana plugs) with a built-on three-way crossover. Save over 40% off the original retail price--the inductors alone are worth over $20--through this Parts Express exclusive factory buyout. All capacitors are electrolytic. Plate dimensions: • Overall: 5-7/16" H x 3-7/8" W • Cutout: 4-9/16" H x 3" W.
A 3,400 Hz 2nd-order Butterworth high-pass for the tweeter uses a 0.6 mH solid-core inductor and a 4 µF capacitor. An L-Pad is formed using a 10 ohm 5 watt resistor is parallel, with an 8 ohm 15 watt resistor in series.
For the midrange section, a 100 Hz, 1st-order Butterworth high-pass filter uses a 250 µF capacitor. The 1,700 Hz 2nd-order Linkwitz-Riley low-pass uses a 1 mH inductor and a 10 µF capacitor. A zobel filter is attached, using a 14 ohm 10 watt resistor and a 16 µF capacitor.
The woofer section features an 8 mH inductor and 150 µF capacitor to comprise a 2nd-order, 150 Hz low-pass filter that follows a Bessel slope.
See the Manuals/Resources section for a crossover schematic.
  • Crossover Type3-Way
  • ConfigurationConnector Dish
  • BrandFactory Buyouts
  • Part Number269-605
  • UPC848864012391
  • Product CategoryAssembled Passive Crossovers
  • Weight1.4 lbs.
View similar products to the NHT M2.3 Speaker Wire Terminal Plate with 3-Way Crossover 150/100 Hz 1,700/3,400 Hz
in the Assembled Passive Crossovers product category.
Customer projects that include: NHT M2.3 Speaker Wire Terminal Plate with 3-Way Crossover 150/100 Hz 1,700/3,400 Hz
