Neutrik Rean NYS322G 5 Pin DIN Plug Gold Contacts
Brand:|Model: NYS322G|Part # 092-152
$1.28
Buy 25-99 $1.25
Buy 100+$1.19
Part # 092-152
  • 5-pin DIN male cable mount
  • 180° pin configuration
  • Durable construction
  • Nickel finish, gold pins
5-pin DIN male cable connector features a diecast shell with nickel plating, flexible strain relief, heavy-duty cable clamp, and complete shielding with ground contact. 180° pin configuration.
Specifications: • Connector type: 5-pin DIN male cable connector • Shell: Nickel • Contacts: Gold plated • Accepts cable O.D. up to 5 mm • Mfg. #NYS 322G.
REAN — a brand of Neutrik AG
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • Conductors5-Pin
  • BrandRean
  • ModelNYS322G
  • Part Number092-152
  • UPC844632004728
  • Product CategoryDIN & Mini DIN Connectors
    (12 Reviews)
  • Weight0.09 lbs.
View similar products to the Neutrik Rean NYS322G 5 Pin DIN Plug Gold Contacts
in the DIN & Mini DIN Connectors product category.
Neutrik Rean NYS322G 5 Pin DIN Plug Gold Contacts is rated 4.75 out of 5 by 12.
Rated 3 out of 5 by from Don't like the ConnectorBought this, build quality is good but I don't like that the connector because it does not secure the cable to the connector. There isn't a strain relief which means your cable is going rip off the connector eventually (which will not take much to do). An example of this is found with Neutrik XLR connectors.Cheap but if you do the A/V work that I do you'll just have problems with this.
Date published: 2012-12-07
Rated 5 out of 5 by from the besthappy to have found these plugs,the best i've ever seen,easy to solder & install,the only ones i'll ever use again.
Date published: 2012-04-17
Rated 5 out of 5 by from Great connectors...great price.Used several of these for making MIDI cables.Very solid, easy to solder and the cable crimp retainer is heavy enough to hold tight. Highly recommended.
Date published: 2012-02-10
Rated 5 out of 5 by from An upgrade over standardI haven't actually wired these yet but taking them apart they appear to be well-made and are a significant upgrade over the din plugs that came with my Quad equipment. Plus, they're a fraction of the cost of competitive products, even after shipping is included.
Date published: 2009-06-09
Rated 5 out of 5 by from Good product for making your own midi cablesI liked the fact the metal strain relief could be removed so soldering the small pins was easy. Then you just re-clipped the strain relief back into place, crimped the cable, put srew into shell and you are done. The finished cables are better than you can buy for 30 times the cost.
Date published: 2009-05-10
Rated 5 out of 5 by from Nice plugEasy to solder, solid connector
Date published: 2009-03-17
  • 2016-02-08T06:48CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_092-152, PRD, sort_mostRecent
Will these Neutrik Rean NYS322G 5 Pin DIN Plugs accept 18 gauge wire
Asked by: ebirky
The pins appear to be too small for 18 gauge wire. Anything from 20-24 gauge will work best.
Date published: 2014-06-20
New to a lot of this DIY audio stuff, but was curious whether this (with MIDI cable) would be a possible solution for connecting pairs of speakers through. I know it's for MIDI but with 5 solderable posts wouldn't 2 speaker lines through one cable work?
Asked by: SoloSymphony
I suppose it could work for this application s long as it is a fairly low power system.
Date published: 2014-03-03
  • 2016-02-07T07:36CST
  • loc_en_US, sid_092-152, PRD, sort_recentQuestionsFirst
