Neutrik Rean NYS231BG 3.5mm Stereo Plug Black with Gold Plug
Brand:|Model: NYS231BG|Part # 092-157
$1.29
Buy 25-99 $1.24
Buy 100+$1.19
Part # 092-157
  • 1/8" stereo (TRS) mini plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged construction
  • Black/gold finish
3.5 mm stereo plug features machined brass construction, oversized solder terminals, heavy-duty crimp strain relief, and knurled handle.
Specifications: • Connector type: 3.5 mm stereo plug (3 pole) • Handle: Black • Contacts: Gold plated • Accepts cable O.D. up to 4 mm • Mfg. #NYS 231BG.
REAN — a brand of Neutrik AG
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • ConductorsStereo (TRS)
  • BrandRean
  • ModelNYS231BG
  • Part Number092-157
  • UPC844632004766
  • Product Category3.5 mm Mini Connectors
    (25 Reviews)
  • Weight0.0187 lbs.
View similar products to the Neutrik Rean NYS231BG 3.5mm Stereo Plug Black with Gold Plug
in the 3.5 mm Mini Connectors product category.
Neutrik Rean NYS231BG 3.5mm Stereo Plug Black with Gold Plug is rated 4.64 out of 5 by 25.
Rated 5 out of 5 by from 3.5mm winning3.5mm Stereo Plug Black with Gold Plug how could you go wrong?these little guys are perfect
Date published: 2014-12-06
Rated 5 out of 5 by from Exactly what I needed...Been using them for about 3 weeks now, they seem durable... A great buy from PE!!
Date published: 2014-11-20
Rated 4 out of 5 by from Great for the priceThis plug is worth the cost. I like the built-in strain relief tabs; they do the job but I had to be careful not to nick the insulation on the wires. The opening is big enough for 4mm worth of cable but the solder tabs are better for smaller wires. I am using 2 pair of 22-gauge wire for the cable + small shielding lead and these are a tad big for the tabs. That's really the only issue I have with them. Good stuff at a great price.I am going to continue buying these.
Date published: 2014-07-05
Rated 5 out of 5 by from Just what I neededLittle parts are hard to find in local electronics stores as they are not exactly big ticket items. Besides tinkerers are a vanishing breed.I expected some cheap connector but this is really well build stuff
Date published: 2014-06-22
Rated 5 out of 5 by from Better Than What Sony OEMMy old stereo plug bit the dust after one year of pampered use on my studio headphones. After watching video on how to replace, I decided to give it a go and ordered two of them (in case I messed the first one up). Lets just say my soldiering skills have much to be desired, but I was successful and now I have a decent backup for the future. They have a nice metal feel without the rubber that came on the headphones to begin with.
Date published: 2014-01-31
Rated 4 out of 5 by from Exactly what I was looking for!I bought this to make an adaptor cable from the 3.5mm plug to a set of high quality RCAs. I used two 24 gauge coax cables attached to the 3.5mm plug, each cable going to one RCA. The two coax cables were a tight fit into the plug and the connection for shield and center conductor were difficult, but it works and I am getting great sound.
Date published: 2014-01-23
  • 2016-02-11T07:01CST
  • co_hasreviews, tv_0, tr_25
  • loc_en_US, sid_092-157, PRD, sort_mostRecent
What type of wire do you offer for this?
Asked by: JamesT
I would use a wire like the Mogami W2552 for this type of application.http://www.parts-express.com/mogami-w2552-superflexible-microphone-signal-cable-1-ft--103-1016
Answered by: Chrisf
Date published: 2016-02-05
Where can I get the recever for the plug?
Asked by: Jerrym
Date published: 2015-02-02
I can't tell , but does this plug have threads to receive a 1/4 inch adapter?
Asked by: Djmabq
This plug is not threaded.
Date published: 2015-01-07
This may sound stupid but i bought stereo headphones when I meant to buy just headphones that I could use with my phone. Does this thing convert the stereo plug into one that I could put into my phone or computer?
Asked by: pepsicola
Not without soldering. Without more information, I recommend this:http://www.parts-express.com/parts-express-1-4-stereo-jack-to-35mm-stereo-plug-adapter--090-347
Answered by: RussR
Date published: 2014-12-08
I know this may sound stupid of me, but why are there only 3 leads instead of 4, are the left and right channels supposed to share a common "ground" or "earth"? Wouldn't that cause distortion & crosstalk, & phase problems?
Asked by: Killer B
On a 3.5mm the grounds are shared. 1/4 inch stereo connectors are also set up that way. While it is better to completely isolate them, this is the way that these two connection formats are set up.
Answered by: Chrisf
Date published: 2014-09-27
can you recommend a good quality cable to use with these (for audio signal cable).
Asked by: ianr
The only cable we have that will properly fit that connector would be listed below.
Date published: 2013-01-23
  • 2016-02-11T07:48CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_092-157, PRD, sort_recentQuestionsFirst
