Neutrik Rean NYS226BG 3.5mm Mono Plug Black
Brand:|Model: NYS226BG|Part # 092-156
$0.99
Buy 25-99 $0.97
Buy 100+$0.93
Part # 092-156
  • 1/8" mono (TS) mini plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged construction
  • Black/gold finish
3.5 mm mono plug features machined brass construction, oversized solder terminals, heavy-duty crimp strain relief, and knurled handle.
Specifications: • Connector type: 3.5 mm mono plug (2 pole) • Handle: Black • Contacts: Gold plated • Accepts cable O.D. up to 4 mm • Mfg. #NYS 226BG.
REAN — a brand of Neutrik AG
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • ConductorsMono (TS)
  • BrandRean
  • ModelNYS226BG
  • Part Number092-156
  • UPC844632004759
  • Product Category3.5 mm Mini Connectors
    (3 Reviews)
  • Weight0.1 lbs.
View similar products to the Neutrik Rean NYS226BG 3.5mm Mono Plug Black
in the 3.5 mm Mini Connectors product category.
Neutrik Rean NYS226BG 3.5mm Mono Plug Black is rated 3.6667 out of 5 by 3.
Rated 2 out of 5 by from Product used to be good...I had purchased this product before from Parts Express and it was excellent; each item was individually packed from the factory. Now that Part Express has repackaged the product the insulating sleeve (shown in the web photo) is no longer included. This opens the possiblity of short circuits and problems for my customers. Chris (PE Tech Support) never followed up on my problem report after 2 calls. Until Parts Express corrects this problem I would say shop somewhere else for this part.
Date published: 2010-07-24
Rated 5 out of 5 by from Solid buildThis plug feels solid. Comes in a package with Japanese writing so I'm sure it's manufactured to precision standards. Easy to solder the terminals.
Date published: 2008-11-07
Rated 4 out of 5 by from Its a plugNice plug - - Took solder easily- Nice closure to cablingI used some heat shrink to add to it but it seems that it would have been fine without. Overall nice plug
Date published: 2007-11-07
  • 2016-02-10T07:00CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_092-156, PRD, sort_mostRecent
The pin itself is 3.5mm and the max cable diameter is 4mm? Really?
I am thinking the cable below should work to make cables with these connectors but it is 6mm. What should be used instead?
Asked by: the one and only babadono
A 22g cable is pretty thin to begin with--so is a 1/8th in plug. I don't know the size of the pin #1 or it's hole, but you can just solder it on--you will have to do that anyway with the ground stem. The plastic sleeve will protect the hot pin from grounding to the screw on jacket. Another option, is to buy these ready made. The cost is as low as making them yourself. I own some PE 1/8th in" cables and no failures. See below.
Answered by: Joe from San Francisco
Date published: 2013-10-22
  • 2016-02-10T07:53CST
  • loc_en_US, sid_092-156, PRD, sort_recentQuestionsFirst
