Neutrik Rean NYS224 1/4" Mono Phone Plug
Brand:|Model: NYS224|Part # 092-130
OUT OF STOCK
Due In: 2/27/2016
$1.19
Buy 25-99 $1.14
Buy 100+$1.08
Part # 092-130
  • 1/4" mono (TS) phono plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged construction
  • Nickel finish
Commercial 1/4" mono plug features a turned brass handle with nickel plating, a larger-than-typical crimp cable clamp, and oversized solder tabs.
 Specifications: • Connector type: 1/4" mono plug (2 pole) • Handle: Nickel • Contacts: Nickel • 44.0 mm long handle; 74.0 mm overall length • Accepts cable O.D. up to 6 mm • Mfg. #NYS 224.
REAN — a brand of Neutrik AG
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • ConductorsMono (TS)
  • BrandRean
  • ModelNYS224
  • Part Number092-130
  • UPC844632004605
  • Product Category1/4" Phone Connectors
    (10 Reviews)
  • Weight0.09 lbs.
View similar products to the Neutrik Rean NYS224 1/4" Mono Phone Plug
in the 1/4" Phone Connectors product category.
Neutrik Rean NYS224 1/4" Mono Phone Plug is rated 4.2 out of 5 by 10.
Rated 5 out of 5 by from Still the best for the money.These 224 and the 201 series Nuetrik/Rean 1/4" plugs are still the best plugs for the money. I've used these, on and off, for close to 30 years. 5 stars based on price to quality and performance.
Date published: 2015-06-14
Rated 4 out of 5 by from Good solid replacement!I bought several of these to repair existing cables and make new ones. They are easy to work with and seem to be well made. Can't beat them for the price.
Date published: 2015-04-21
Rated 5 out of 5 by from Good connectorSeems well constructed. Comes with insulating sleeve (not all connectors come with those). Solder adheres to the terminals quite well (remember to use flux...ALWAYS use flux). Connector seats into standard 1/4 jacks, not too loose, not too tight. I'll buy this one again if the need arises.
Date published: 2012-05-19
Rated 4 out of 5 by from SimpleThis connector is pretty basic. It is durable and did the job for me. I have used it for both speaker cables with 14awg wire and instrument cables. It was a very tight fit with the speaker wire. I'd recommend spending a little more and getting a connector specifically for speaker wire.The only real complaint I have is there is no solder tab for the ground wire. Its hard to get it to stick to the bottom without the wire touching the positive contact.Instead of using the plastic insulator sleeve I used a couple inches of heatshrink for a more professional look.
Date published: 2011-12-23
Rated 4 out of 5 by from Very good productI tried the plug on recommendations from previouscustomers which proved to be correct.Used for speaker wire hookup. Very good for the price. Highly recommend.
Date published: 2009-06-29
Rated 4 out of 5 by from Good for the moneyThis plug is fine for most applications. Well built considering the low price.
Date published: 2009-06-13
  • 2016-02-05T06:46CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_092-130, PRD, sort_mostRecent
Can you tell me what size threads this has where the two pieces screw together?
Asked by: cctek
After measuring it the best I can determine is that it is metric with a outer thread diameter of 10.67mm by a thread of 1.0mm.
Answered by: VictorE
Date published: 2012-01-04
  • 2016-02-05T07:13CST
  • loc_en_US, sid_092-130, PRD, sort_recentQuestionsFirst
