Neutrik NTE1 1:1 Audio Adapter Transformer for NMxxx Modules
Brand:|Model: NTE1 |Part # 092-2247
Neutrik's adapter modules allow the user to design and implement their own custom adapters and cables, rather than relying on "off-the-shelf" solutions or using more than one adapter at a time. The NTE1 is a 1:1 professional audio transformer with wire leads, designed to integrate with NMxxx adapter modules.
$9.87
Buy 25-99 $9.06
Buy 100+$8.46
Part # 092-2247
  • 1:1 professional audio transformer
  • Use with 1/4", RCA, or XLR modules to create your own custom adapters
  • Wiring and soldering required
The NTE1 is a 1:1 professional audio transformer with color-coded wire leads, designed to integrate with NMxxx adapter modules. Typical applications may include general signal splitting and inline audio adapters.
Click this text to see the entire line of Neutrik adapter modules and accessories.
XLR, RCA, and 1/4" modules are available in male and female, as well as various couplers and even a cable end module with Neutrik's chuck-type strain relief. Wiring and soldering is required. All Neutrik modules meet the IEC 68-2-20 standard for solderability, and are constructed with the same rugged reliability you've come to expect from Neutrik.
  • BrandNeutrik
  • ModelNTE1
  • Part Number092-2247
  • UPC848864015828
  • Product Category1/4" Phone Adapters
    (2 Reviews)
  • Weight0.0200 lbs.
View similar products to the Neutrik NTE1 1:1 Audio Adapter Transformer for NMxxx Modules
in the 1/4" Phone Adapters product category.
Neutrik NTE1 1:1 Audio Adapter Transformer for NMxxx Modules is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Just what I neededI had a ground issue that was messing up my stereo on the motorcycle. I used them as isolation transformers for the speaker system and they solved my problem. Small in size and efficient - just what I needed.
Date published: 2015-09-21
Rated 5 out of 5 by from Perfect for eliminating Bluetooth noise!In my situation, I was powering a bluetooth audio adapter and a small 7-watt mono amplifier from the same power source. I was getting very loud digital noise... beeps and clicking and such as soon as the bluetooth established a connection. It was a ground loop issue. I was able to solve the noise problem by installing this 1:1 isolation transformer on the audio wires between the bluetooth receiver and the audio amp. This isolated the audio circuits and eliminated 99% of the noise.The red and black leads connected to the bluetooth side, while the yellow and white leads from the transformer connected to the audio amp side. This gave me the best bass response and rolled the high end off a little bit. Reversing the transformer seemed to roll of the low end while maintaining the highs. You can try and both ways and see what sounds best to you. Hope this helps someone else having bluetooth audio problems when running from the same power source.
Date published: 2015-03-21
  • 2016-02-11T07:00CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_092-2247, PRD, sort_mostRecent
If I want to use this with the Sure 15W amplifier (AA-AB32155), do I need to use 1 transformer per channel?
Asked by: Rhys E
I want to chain several audio amplifiers (PA monitors) from 1 source and I'm told they need to be electrically isolated. Would this item be suitable for that application? Is there a signal loss because of this transformer being in line to the next amp?
Asked by: Gunnar
Date published: 2015-01-16
  • 2016-02-11T07:48CST
  • loc_en_US, sid_092-2247, PRD, sort_recentQuestionsFirst
