Neutrik NP2X Plug 1/4" Mono Nickel/Silver
Brand:|Model: NP2X|Part # 092-316
The new PX Series improves on the design of the existing phone plug by offering the thinnest available 1/4" plug on the market, featuring the unique Neutrik chuck type strain relief.
$2.98
Buy 25-99 $2.86
Buy 100+$2.69
Part # 092-316
  • 1/4" mono (TS) phono plug
  • Make your own cables to the perfect length
  • Repair your own cables and save money
  • Rugged diecast construction
  • Nickel finish
The new PX Series improves on the design of the existing phone plug by offering the thinnest available 1/4" plug on the market, featuring the unique Neutrik chuck type strain relief. The new plugs meet the most recent requirements for highest packing density, which is 15.88mm jack pitch. The PX Series 1/4" professional phone plugs are available in mono (2 contacts/TS) or stereo (3 contacts/TRS). Cable O.D.: 4 - 7mm.
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • ConductorsMono (TS)
  • BrandNeutrik
  • ModelNP2X
  • Part Number092-316
  • UPC7613187000737
  • Product Category1/4" Phone Connectors
    (5 Reviews)
  • Weight0.08 lbs.
View similar products to the Neutrik NP2X Plug 1/4" Mono Nickel/Silver
in the 1/4" Phone Connectors product category.
Neutrik NP2X Plug 1/4" Mono Nickel/Silver is rated 4.6 out of 5 by 5.
Rated 5 out of 5 by from solid pluggreat quality plug,should last a long time,glad to find these for my new speakers.
Date published: 2015-01-29
Rated 5 out of 5 by from Great connectorI typically buy cheaper connectors - then end up replacing them over and over. I was very impressed with the solid construction of these and their well designed construction. Easy to install and sure to last!
Date published: 2014-03-23
Rated 5 out of 5 by from Neutrik NP2X Plug 1/4" Mono Nickel/Silver >>Awesome plugsI purchased a bunch of used cables from a friend and rebuilt them with these neutrik ends. If you are good with a soldering iron they assemble easly. High quality stuff! I will buy more.
Date published: 2012-04-13
Rated 4 out of 5 by from outdoes switchcraft!!good solid 1/4 inch connector! goes together securely/comes apart easily; and is well made.i suggest that all who buy this to get a pencil soldering tool- guns could cause damage at assembly.once that said, it is a great 1/4" plug!
Date published: 2010-07-23
Rated 4 out of 5 by from Expensive, but worth it.Engineered very well. Easy to solder when you follow the directions. Very solid feeling.
Date published: 2008-10-15
  • 2016-02-07T07:10CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_092-316, PRD, sort_mostRecent
i,m using 16g speaker wire will this plug accomodate that
Asked by: tattoolloyd
Yes. It will accept a cable O.D. from 4mm to 7mm
Answered by: TomI
Date published: 2015-03-24
What is the maximun cable diameter I can use with this conector?
Asked by: Cesar Acuña
The maximum cable diameter for this connector is 7mm.
Date published: 2015-01-20
Are they compatible with Carol 12awg 2CSJ cable?
Thanks
Asked by: Richie P
Unfortunately these plugs are designed for smaller signal wire for microphones or instruments. I would recommend a bigfoot type plug for speaker cable that size.
Date published: 2013-01-16
  • 2016-02-07T07:30CST
  • loc_en_US, sid_092-316, PRD, sort_recentQuestionsFirst
