Neutrik NO4FDW-A opticalCON QUAD Feed-thru Chassis Mount
Brand:|Model: NO4FDW-A|Part # 092-2208
Neutrik's opticalCon connector system provides solutions for data transfer in harsh demanding environments by offering a cable carrier and receptacle that helps to protect the contacts of the connections.
Part # 092-2208
  • Rugged 4-channel point-to-point multichannel routing solution
  • Laser protected metal automatic sealing shutter
  • Accommodates standard LC connectors on the rear for simple installation
  • Water resistant according to IP65 ingress protection in mated condition
Frequently Bought Together
The NO4FDW-A is a chassis connector with black chromium plating, waterproof rated to IP65, front panel mount. The chassis connector acts as a "feed-through" allowing simplified installations by connecting four conventional LCs on the rear. It is built in the standard D Series shell and features an automatic sealing cover for maximum dust and dirt protection and a Push-Pull locking mechanism for safe connection. Colored sealings are included to identify the fiber mode. The two piece rubber gasket on the laser protected metal shutter protects optical connection from dust and dirt. Color coded rubber seals are included to identify fiber mode: multimode - black; single mode PC - blue; single mode APC - green.
  • BrandNeutrik
  • ModelNO4FDW-A
  • Part Number092-2208
  • UPC848864014838
  • Product CategoryNeutrik opticalCON Fiber Optic System
  • Weight0.08 lbs.
View similar products to the Neutrik NO4FDW-A opticalCON QUAD Feed-thru Chassis Mount
in the Neutrik opticalCON Fiber Optic System product category.
