Neutrik NO2-4FDW-1-A opticalCON DUO LC-Duplex Feed-thru with Ground Chassis Mount
Brand:|Model: NO2-4FDW-1-A|Part # 092-2206
Neutrik's opticalCon connector system provides solutions for data transfer in harsh demanding environments by offering a cable carrier and receptacle that helps to protect the contacts of the connections.
$87.91
Buy 25-99 $82.01
Buy 100+$77.81
Part # 092-2206
  • Designed as feedthrough with automatic sealing shutter
  • Accommodates standard LC connectors on the rear for simple installation
  • Connection on the front side either by rugged opticalCON or standard LC connector
  • Water resistant according to IP65 ingress protection in mated condition
The NO2-4FDW-1-A is a chassis connector with black chromium plating, 4 solder contacts and 1 LC-Duplex feedthrough socket and 1 shell ground contact (for SMPTE cable shield), waterproof rated to IP65, front panel mount. The chassis connector acts as a "feed-through" allowing simplified installations by connecting a conventional LC-Duplex on the rear. It is built in the standard D Series shell and features an automatic sealing cover for maximum dust and dirt protection and a Push-Pull locking mechanism for safe connection. Colored sealings are included to identify the fiber mode. The silicone gasket on the shutter protects optical connection from dust and dirt, and in cases of extremely limited space, it can be mounted without the rubber gasket. The IP rating for this is IP 52. Not compatible to SMPTE 344M standard. Suitable for indoor (studio) camera links considering specific conditions acc. to IEC 60664-1 like pollution degree 1, overvoltage category 1 and rated voltage. Color coded rubber seals are included to identify fiber mode: multimode - black; single mode PC - blue; single mode APC - green.
  • BrandNeutrik
  • ModelNO2-4FDW-1-A
  • Part Number092-2206
  • UPC7613187007811
  • Product CategoryNeutrik opticalCON Fiber Optic System
  • Weight0.07 lbs.
View similar products to the Neutrik NO2-4FDW-1-A opticalCON DUO LC-Duplex Feed-thru with Ground Chassis Mount
in the Neutrik opticalCON Fiber Optic System product category.
I am using one of your multimode fiber optic Tactical cables and running it into an LC Duplex feed through socket, but the tactical cable is not locking into the socket.  Every time the cable is plugged in, it will pop out and interrupt the connection.
Asked by: Ben J
Date published: 2014-10-08
  • 2016-02-07T07:35CST
  • loc_en_US, sid_092-2206, PRD, sort_recentQuestionsFirst
