Neutrik NLT8MP Speakon STX 8P Male Chassis Connector Nickel
Neutrik NLT8MP Speakon STX 8 Pole Male Chassis Connector Nickel Housing
Brand:| Model: NLT8MP
Neutrik's NLT8MP is an 8 pole male Speakon chassis connector, with Nickel housing, and 1/4" flat tabs for quick disconnects or solder.
  • Current rating 40 Amp continuous, 50 Amp audio with 50% duty cycle
  • Robust and durable all metal housing
  • Reinforced metal quick lock system for ease and precise locking
  • Mate with all available SpeakonĀ® products
092-346
Weight: 0.12 lbs.
IN STOCK
List Price$14.12
You Save11%
$12.55
Buy 50-99 $12.22
Buy 100-up$11.89
Part # 092-346
The new STX Series is the next generation of 8 pole speakON connectors especially designed for heavy duty amplifier-loudspeaker applications like professional tour sound. The extremely rugged and durable STX Series feature an all metal housing and metal reinforced latch lock system.
Product
Connector TypeSpeakon
GenderMale
Electrical
Contact resistance<2 mΩ (after lifetime)
Dielectric strength3 kVdc (peak)
Insulation resistance>10 GΩ (after dampheat)
Rated current per contact40A RMS continuous
Rated current per contact50A audiosignal, duty cycle 50%
Rated voltage250V (Insulation)
AttentionSpeakON is NOT to be used as an AC mains connector!
Mechanical
Lifetime>5,000 mating cycles
WiringFlat tabs for 1/4" (FASTON® 6.3 x 0.8 mm) or soldering
Locking deviceQuick lock
Mounting directionFront and rear
Chassis shapeSquare G-size flange
LayoutFour thru holes
Material
Contact plating4 µm Ag
ContactsSpring copper (CuSn0.2)
InsertPolyamide (PA 6 30% GR)
ShellZinc diecast (ZnAl4Cu1) Ni
Environmental
FlammabilityUL 94 HB
Protection classIP 52 (mated condition)
SolderabilityComplies with IEC 68-2-20
Temperature range-30°C to +80°C
  • Circuit8-Pole
  • Mounting TypeChassis / Panel Mount
  • GenderMale
  • BrandNeutrik
  • ModelNLT8MP
  • Part Number092-346
  • UPC844632095795
  • Product CategoryspeakON / HPC Speaker Connectors
    (2 Reviews)
  • Weight0.12 lbs.
View similar products to the Neutrik NLT8MP Speakon STX 8 Pole Male Chassis Connector Nickel Housing
in the speakON / HPC Speaker Connectors product category.
Neutrik NLT8MP Speakon STX 8 Pole Male Chassis Connector Nickel Housing is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Looks VS. PriceWhen I read nickel face plate I thought awesome, But its a nickel cover over plastic its a great look but it comes at higher cost but I don't plan on re-working this rack for a long time so I figured what the heck. (the regular plastic Neutric case connectors are plenty durable)
Date published: 2013-08-10
Rated 5 out of 5 by from Every part of the Neutrix line makes sense, They "get" good designI went for the metal, looks great, matches the plug, and I have carefully chosen units to code their use by look alone. I am one to over-spec a product in general which has saved me many a time. But this is not over-spec, it is a perfect match for my needs. I am expecting a lot of rough use in the field.. by folks "helping me" setup my system. This is part of a well thought out product line, GREAT design, beautiful engineering, and outstanding attention to detail in the production. Silky smooth threads, a cable grip that will NOT let loose (be carefull, DO NOT screw it together as you admire it... it goes together ONCE and LOCKS - I speak from experiance.. I almost went too far, thankfully I was able to back it off - barely... LOL. Trust me.). I have a large project of mine for a mobile RC Ground Control Unit, and am using this to handle the speaker connections. I have not been this impressed by a connector in all my 50+ years as a designer. Well worth every penny. Check out ALL the Neutrix .. I ordered 4 sets of different kinds.. ALL are JUST perfect.. and am going to order more of their product.
Date published: 2012-12-22
Customer projects that include: Neutrik NLT8MP Speakon STX 8 Pole Male Chassis Connector Nickel Housing
