Neutrik NL2FX Speakon Connector 2 Pole Cable Mount
Brand:|Model: NL2FX|Part # 092-198
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the original "quick lock" locking system. The NL2FX replaces and improves upon the popular NL2FC, and will mate with 4-pole speakON chassis connectors.
$2.99
Buy 25-99 $2.85
Buy 100-999 $2.78
Buy 1000+$2.72
Part # 092-198
  • Durable shell construction, easy and fast tool-less assembly
  • Contacts are touch-proof and meet all safety requirements
  • Reliable and nearly universal 2-pole connector for pro PA applications
  • Improved latching mechanism
Neutrik's NL2FX speakON connector replaces the incredibly popular NL2FC with an even easier-to-use feature set, while retaining the ruggedness, reliability, and attributes that have made speakON the industry standard for speaker and amplifier connections. The NL2FX features solid contacts with screw-type terminals including a stranded wire protection which also allows for solder termination. Only three parts make installation a breeze, and since no special tools are required, these connectors remain 100% field repairable.
The contacts in this series are touch-proof and designed to prevent damage from arcing if disconnected under load, ensuring fail-safe conditions for both the equipment and the operator. All speakON connectors meet the prevailing safety standards of IEC65, IEC348, CE, and CSA, and are UL rated (file #E135070). A truly superior 2-pole device for PA amplifier-to-speaker connections!
Specifications: • Connector type: Cable end connector, 2-pole • Current rating: 40A continuous; 50A audio signal with 50% duty cycle • Accepts 6-10 mm OD cable. • Mfg. #NL2FX.
Note: Intermates with 4-pole speakON chassis connectors and makes contact with +1/-1.
  • Circuit2-Pole
  • Mounting TypeCable Mount
  • GenderMale
  • BrandNeutrik
  • ModelNL2FX
  • Part Number092-198
  • UPC7613187007606
  • Product CategoryspeakON / HPC Speaker Connectors
    (18 Reviews)
  • Weight0.0600 lbs.
View similar products to the Neutrik NL2FX Speakon Connector 2 Pole Cable Mount
in the speakON / HPC Speaker Connectors product category.
Neutrik NL2FX Speakon Connector 2 Pole Cable Mount is rated 5.0 out of 5 by 18.
Rated 5 out of 5 by from Excellent productThese are solid, high quality connectors that are extremely easy to install and function flawlessly.
Date published: 2015-10-12
Rated 5 out of 5 by from TIGHT!Obviously most excellent in every way. Do yourself the favor, grab a roll of cable and some of these and make your own cables with a screw driver and a steak knife... or wire stripper ;)
Date published: 2015-07-11
Rated 5 out of 5 by from Great connectorPreferred over the A named brand. Better wire clamping mechanism and smoother locking tab. Great connector.
Date published: 2015-05-05
Rated 5 out of 5 by from well constructedeasy to make up your own cables with these. very satisfied with the quality
Date published: 2015-03-27
Rated 5 out of 5 by from Genuine real dealFirst, I don't understand why people who build their own speaker cable with a 14/2 or 12/2 cable, and then buy a more expensive 4 pole speakon connector than the nl2fx 2 pole connector. Second, these new speakon connectors are waayyy easier to use than the older one. Easier access to clamp screws and easier time to screw the main body down the the end. And one last thing for me, parts express equals best price, best shipping, and best buying information.
Date published: 2015-03-18
Rated 5 out of 5 by from Same as NL4 for two-wire cableGreat replacement for NL4s when you are only using a two-wire cable. I hated the old NL2 connectors, but these are just like the NL4 in shape and function.....and cheaper.
Date published: 2014-11-08
  • 2016-02-08T06:48CST
  • co_hasreviews, tv_0, tr_18
  • loc_en_US, sid_092-198, PRD, sort_mostRecent
Can i use this for a + and - cable of a 12v electric boat motor? And which femaleholder do i have to take for this male plug?
Asked by: Mikeyszz
Not likely, I assume a trolling motor which would require heavier gauge wire than this could handle. I would advise you stick with marine equipment supply as they would have products specific to your application.
Answered by: DJohn
Date published: 2015-09-04
What kind of cable does it have, like the wire
Asked by: Klein
This does not include a cable, this is only the cable mount connector.
  • 2016-02-07T07:36CST
  • loc_en_US, sid_092-198, PRD, sort_recentQuestionsFirst
