Neutrik NJ3FC6 1/4" In-Line Locking Jack
Brand:|Model: NJ3FC6|Part # 092-134
This series features the Neutrik innovation of a securely locking 1/4" jack with latch release. Mates with all mono or stereo plugs. This cable mount version can accept cable up to 8 mm OD.
$6.18
Buy 25-99 $5.69
Buy 100+$5.41
Part # 092-134
  • 1/4" stereo (TRS) cable mount jack, locking
  • Accommodates cable up to 8mm O.D.
  • Rugged diecast construction
  • Nickel/black finish
This series features the Neutrik innovation of a securely locking 1/4" jack with latch release. Mates with all mono or stereo plugs. This cable mount version can accept cable up to 8 mm OD. Also available in a panel mount version that features the same hole cut-out as the "D" series panel mount receptacles. Rugged diecast nickel shell with silver contacts. Mfg. #NJ3FC6.
  • GenderFemale / Jack
  • Mounting TypeCable Mount
  • ConductorsStereo (TRS)
  • BrandNeutrik
  • ModelNJ3FC6
  • Part Number092-134
  • UPC703272019977
  • Product Category1/4" Phone Connectors
    (7 Reviews)
  • Weight0.09 lbs.
View similar products to the Neutrik NJ3FC6 1/4" In-Line Locking Jack
in the 1/4" Phone Connectors product category.
Neutrik NJ3FC6 1/4" In-Line Locking Jack is rated 4.2857 out of 5 by 7.
Rated 5 out of 5 by from Solid 1/4" JackUsing these to make custom cables for my headphones. The locking feature keeps the cable from disconnecting if moving around
Date published: 2015-05-27
Rated 5 out of 5 by from Very Solid..butThis plug is well built but the locking mechanism is a bit too hard tounlock the male plug from it. Would be perfect if this issuecould be fixed.DCFantastic Recording & Sound Co.
Date published: 2015-04-10
Rated 5 out of 5 by from i love this thingI use this on Pro Audio stuff.I could not be happier with this unless it was super cheap. It's affordable, and easy to work with. Just be careful when you are working with it- the locking mechanism can come out and apart from the jack when disassembled. There is an orange hinge, a foam block the spring and the button piece. They all very small. It will still work if you lose the spring (guess how I found out). But the locking has to be done by you. With the spring, it locks when you plug it in.This is a very sturdy alternative to the traditional in-line jacks, though it does cost a bit more.
Date published: 2012-03-07
Rated 1 out of 5 by from In A Word......JunkI recently bought some of these to make a pigtail to take my commercial amps spade lug connections to 1/4". Do not attempt to try and use these with any gauge speaker wire over 16 AWG. They are totaly useless for several reasons. First the solder lugs are way too small for 12 AWG wire; not only the hole size but also the thin material the solder lugs are made from. Secondly the description indicates the strain relief are capable of handling large diameter cable (up to 8mm), that is totally incorrect as I could not get the strain relief to fit my 12 AWG speaker cable which was a bit smaller than the 8mm as specified. I ruined one trying to make it fit around the speaker cable. Also you will have to modify the rubber boot to fit around any cable larger than 2mm to even get the cable to pass thru. I was very disappointed in these connectors and would not recommend them for any speaker cable large than 16AWG. Spend the extra money and buy the large body Switchcraft Connectors! Neutrik failed on this product!
Date published: 2011-08-12
Rated 4 out of 5 by from Great locking featureI recently bought some of these to make a pigtail to take my commercial amps spade lug connections to 1/4", for easier use in a mobile application. The locking feature is great! I only wish that the solder lugs were larger to better support heavy duty speaker cables. But these are much, much sturdier than most anything else I've tried. I'll be buying more of these.
Date published: 2010-03-20
Rated 5 out of 5 by from Excellent productThis is exactly what I was looking for. Stereo TRS, locking function, easy to solder, well made. So far no complaints.
Date published: 2009-04-23
  • 2016-02-05T06:46CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_092-134, PRD, sort_mostRecent
Is this available in black?
Asked by: bassistom
Yes it is available. NJ3FC6 is 3 pole nickel plated housing and the NJ3FC-BAG is 3 pole Black housing both have colored boots available (10 colors) for coding and marking identification. These connectors have the excellent Neutrik Boot/cable grip strain relief that is the best system available. Very easy to install and remove.
Answered by: bigrich
Date published: 2013-09-17
  • 2016-02-05T07:13CST
  • loc_en_US, sid_092-134, PRD, sort_recentQuestionsFirst
