Neutrik NC3MD-L-1 XLR "D" Series Panel Mount Male Nickel
Brand:|Model: NC3MD-L-1|Part # 092-034
In this series, the male and female fit in the same hole cut-out and are front or rear mountable. The "D-L-1" Series features a one-piece unit with solder cup terminations. It is RF protected via a 3-point coaxial ground contact shell of the mated connector. This series is very cost effective.
$2.67
Buy 25-99 $2.50
Buy 100+$2.36
Part # 092-034
  • The worldwide standard for XLR cable connectors
  • D Series front or rear panel mount
  • Male 3-pin XLR for mics and audio lines
Specifications: • Connector type: XLR male • Shell: Nickel • Contacts: Silver • Mfg. #NC3MD-L-1.
  • GenderMale
  • Mounting TypeChassis / Panel Mount
  • Conductors3-Pin
  • BrandNeutrik
  • ModelNC3MD-L-1
  • Part Number092-034
  • UPC703272019144
  • Product CategoryXLR Connectors
    (6 Reviews)
  • Weight0.047 lbs.
View similar products to the Neutrik NC3MD-L-1 XLR "D" Series Panel Mount Male Nickel
in the XLR Connectors product category.
Neutrik NC3MD-L-1 XLR "D" Series Panel Mount Male Nickel is rated 4.8333 out of 5 by 6.
Rated 4 out of 5 by from solid, well built piecesI bought the neutrik male XLR panel mount plugs for use in a PA rack - they performed up to expectations...
Date published: 2015-09-23
Rated 5 out of 5 by from The Perfect Panel MountIt's sturdy and solid.It has a good finish and looks good.
Date published: 2012-04-17
Rated 5 out of 5 by from Neutrik is the only way to goNeutrik parts are the best. Specs are easy to find. Quality is top notch. Parts last forever.
Date published: 2010-12-14
Rated 5 out of 5 by from Excellent product.You can't go wrong with Neutrik. I used these to replace some off-brand connectors in a patchbay that was quite worn out. I'd like to note that these will accept #4 screws as well as the metric screws that Neutrik specifies.
Date published: 2010-02-01
Rated 5 out of 5 by from Clean, neat - worksEasy to work with and set up. Just what you want.
Date published: 2009-06-01
Rated 5 out of 5 by from Good panel mount XLRIt'ss a Neutrik. I have never been disapointed by a Neutrik product. They always seem to do there job well.
Date published: 2007-12-10
  • 2016-02-12T06:43CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_092-034, PRD, sort_mostRecent
what screws size (part number) do I use to mount these to the cut outs?
Asked by: srmorton
Neutrik's recommendation is below.SCREWSScrews for chassis connectors depend on panel material and panel thickness. We suggest the following:Metal panel (Steel, Aluminum, Zinc)Flat head thread forming screws, Pozidriv, DIN 7500 M, zinc plated, M3 x length (drilled hole ~ 3.1 mm)Flat head metric machine screws, Pozidriv, DIN 965A, zinc plated, M3 x length (thread M3)Plastic PanelsPT-flat head screws, WN 1413, zinc plated, KA30 x length (depends on material, ~ 2.4 mm)For various chassis mount versions we offer correspondig screws. (A-Screw-1-8, B-Screw-1-8, E-Screw-1-12)RIVETSIt is possible to use any aluminum 1/8'' or 3.2 mm 90° countersunk blind rivet. We suggest drilling a hole diameter of 3.3mm for the panel. It is possible to use pneumatic, electrical or hand riveting tools.
Date published: 2014-07-09
  • 2016-02-12T07:15CST
  • loc_en_US, sid_092-034, PRD, sort_recentQuestionsFirst
