Neutrik NBB75SI BNC Chassis Mount Solder Tab
Brand:|Model: NBB75SI|Part # 092-262
Neutrik connectors are the choice of professionals everywhere. This BNC feed-through is an ideal choice when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors.
$5.69
Buy 25-99 $5.49
Buy 100+$5.10
Part # 092-262
  • BNC female to solder tabs
  • Isolated from chassis/panel
  • Durable construction
  • Nickel finish
BNC Bulkhead Chassis Connectors. Based on a new production technology, the machined brass connector body provides and extremely rugged and non-abrasive connection over long term use. They are an ideal combination when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors. Available in isolated or grounded versions, in "D" shaped housing or single feed through chassis mountings. Isolated versions solve potential grounding problems and prevent common-mode influence with other connections conducted over the same panel ground potential. Gold plated center contact. Excellent return loss / VSWR rating.
• Connector Type: BNC Isolated Chassis w/Solder Tabs • Housing: n/a • Shell Color: Nickel • Mfg. #NBB75SI
  • GenderFemale
  • Mounting TypeChassis / Panel Mount
  • BrandNeutrik
  • ModelNBB75SI
  • Part Number092-262
  • UPC844632005060
  • Product CategoryBNC Connectors & Adapters
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the Neutrik NBB75SI BNC Chassis Mount Solder Tab
in the BNC Connectors & Adapters product category.
