Neutrik NBB75FG BNC Feed-Through Grounded Nickel
Brand:|Model: NBB75FG|Part # 092-252
Neutrik connectors are the choice of professionals everywhere. This BNC feed-through is an ideal choice when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors.
$6.49
Buy 25-99 $6.38
Buy 100+$5.95
Part # 092-252
  • BNC female to female coupler, non-isolated
  • Chassis or panel mount
  • Durable construction
  • Nickel finish
BNC Bulkhead Chassis Connectors. Based on a new production technology, the machined brass connector body provides and extremely rugged and non-abrasive connection over long term use. They are an ideal combination when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors. Available in isolated or grounded versions, in "D" shaped housing or single feed through chassis mountings. Isolated versions solve potential grounding problems and prevent common-mode influence with other connections conducted over the same panel ground potential. Gold plated center contact. Excellent return loss / VSWR rating.
• Connector Type: BNC Grounded Feed Through • Housing: n/a • Shell Color: Nickel • Mfg. #NBB75FG
  • GenderFeedthrough
  • Mounting TypeChassis / Panel Mount
  • BrandNeutrik
  • ModelNBB75FG
  • Part Number092-252
  • UPC844632005022
  • Product CategoryBNC Adapters
    (1 Reviews)
  • Weight0.1 lbs.
View similar products to the Neutrik NBB75FG BNC Feed-Through Grounded Nickel
in the BNC Adapters product category.
Neutrik NBB75FG BNC Feed-Through Grounded Nickel is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Pretty good bulkhead BNC connectorThe machining of this item is really quite good. I'm giving it 4 stars instead of 5 only because it requires a D-shaped hole. If you use a round hole, there is no way to hold the connector while tightening the nut. The male part does not have a hex for a wrench. I used a moto-tool to grind a suitable D-shaped hole which worked perfectly.
Date published: 2014-03-09
  • 2016-02-09T06:44CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_092-252, PRD, sort_mostRecent
