Neutrik NBB75DFGB BNC "D" Feed-Through Grounded Black
Brand:|Model: NBB75DFGB|Part # 092-260
Neutrik connectors are the choice of professionals everywhere. This BNC feed-through is an ideal choice when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors.
  • BNC female to female coupler, non isolated
  • Familiar "D" Series frame
  • Durable construction
  • Black finish
BNC Bulkhead Chassis Connectors. Based on a new production technology, the machined brass connector body provides and extremely rugged and non-abrasive connection over long term use. They are an ideal combination when used in conjunction with Neutrik 75 ohm BNC Rear Twist or Push-Pull cable connectors. Available in isolated or grounded versions, in "D" shaped housing or single feed through chassis mountings. Isolated versions solve potential grounding problems and prevent common-mode influence with other connections conducted over the same panel ground potential. Gold plated center contact. Excellent return loss / VSWR rating.
• Connector Type: BNC Grounded Feed Through • Housing: "D" Series • Shell Color: Black • Mfg. #NBB75DFGB
  • GenderFeedthrough
  • Mounting TypeChassis / Panel Mount
  • BrandNeutrik
  • ModelNBB75DFGB
  • Part Number092-260
  • UPC844632005053
  • Product CategoryBNC Connectors & Adapters
  • Weight0.1 lbs.
View similar products to the Neutrik NBB75DFGB BNC "D" Feed-Through Grounded Black
in the BNC Connectors & Adapters product category.
