Neutrik NAUSB-W-B Feed-thru Reversible USB A/B Adapter D Panel Mount Black
Brand:|Model: NAUSB-W-B|Part # 092-279
The digitization of professional audio/video equipment has risen exponentially in recent years. For a solid and reliable interface between audio/video networks, IT equipment, cameras, recorders, and so forth, a rugged solution is needed. As always, Neutrik has you covered.
$5.49
Buy 25-99 $5.17
Buy 100+$4.94
Part # 092-279
  • USB 2.0 gender changer type A-B (or B-A)
  • Reversible insert
  • Removable screen to chassis grounding
  • Ideal for audio networking and integration of computer-based equipment
  • Black housing
Neutrik's NAUSB-W-B, a reversible USB gender changer, is mounted in the standardized D-shape housing. It offers an elegant and reliable solution the problems related to integrating digital connections between your equipment. Built to the USB 2.0 standard, it's built to take the punishment of frequent use for years to come.
  • BrandNeutrik
  • ModelNAUSB-W-B
  • Part Number092-279
  • UPC7613187005015
  • Product CategoryUSB Connectors
    (3 Reviews)
  • Weight0.06 lbs.
View similar products to the Neutrik NAUSB-W-B Feed-thru Reversible USB A/B Adapter D Panel Mount Black
in the USB Connectors product category.
Neutrik NAUSB-W-B Feed-thru Reversible USB A/B Adapter D Panel Mount Black is rated 4.6667 out of 5 by 3.
Rated 4 out of 5 by from Excellent product, but can't get it working.I was building a custom flight case for my DJ set up, and i purchased this item to make a panel mount USB access, instead of getting behind the DJ mixer. There isn't a right and wrong way to connect this item, but for some strange reason, it doesn't connect my laptop to my mixer. Both cables work directly from my mixer to my laptop, but with the USB connector it doesn't.Will upload some photos later...
Date published: 2015-12-31
Rated 5 out of 5 by from Perfect connector for my panel!Happy to have found this here - just what I needed. It's not difficult at all to install, orreverse the connections.
Date published: 2014-02-27
Rated 5 out of 5 by from Solid connector, worth the money for critical applicationsThe metal housing on this Neutrik connector is tough and the USB ports should handle lots of plugging and unplugging. It is a little pricey but you get what you pay for and this thing is industrial grade. I used it on an amplifier project to provide a charging port for my iphone. The mounting hole is 15/16" which most uni-bits won't do so that was bit tricky but I found one on amazon for cheap and it did the job. It gives a clean and professional look on the back panel of the anodized aluminum amp chassis. I haven't tried to reverse the connector but it looks simple enough to flip around and make the A connector internal and the B connector external .
Date published: 2013-03-05
  • 2016-02-14T07:09CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_092-279, PRD, sort_mostRecent
I need of these but for the micro USB cables.  Do you have one?
Asked by: Drakk
We do not have any that accept a micro USB.
Date published: 2015-02-17
Can you tell me once it is mounted how far does it stick out?
Asked by: Salespo
This protrudes 3/16" from the mounting surface.
Date published: 2014-12-04
Does this connection support USB 3.0? Thanks.
Asked by: Matt Dahg
This connector is not rated for USB 3.0. It is only compatible up to USB 2.0
Answered by: Chrisf
Date published: 2014-09-27
Are both sides "recepticles"
In other words, one side is what you would normally see on a computer/laptop and the other side is what you would see on a large accessory such as a printer? You could then use a standard USB cable on either side of this connector.
Asked by: rif314
Yes the front (Black part) is a Female USB type A connector and the back is a Female USB type B connector. The connectors are reversible, so you can put the type B on the front and type A on the back or keep as is. As a reviewer has stated, the hole cutout is 15/16"
Answered by: JDoyner
Date published: 2013-04-09
  • 2016-02-14T08:01CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_092-279, PRD, sort_recentQuestionsFirst
