Neutrik NAC3MPB powerCON Chassis Connector Power Out Gray
Brand:|Model: NAC3MPB|Part # 092-286
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. • Connector: PowerCon® chassis connector • Type: Power Out • Color: Gray (B) • Mfg. #NAC3MPB
$2.99
Buy 25-99 $2.89
Buy 100+$2.68
Part # 092-286
  • 3-conductor quick disconnect terminations for easy and reliable assembly
  • Field serviceable, robust, and unbreakable
  • Fail-safe, long life electrical termination integrity
  • Developed for frequently connected/disconnected systems with operator and equipment safety in mind
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. Color coded for easy identification, PowerCon® offers power-in (blue) and power-out (gray) versions with different keying to avoid the possibility of short circuiting. The contacts are designed to prevent damage from arcing when disconnected while under load. PowerCon® meets or exceeds the demands of applications in the fields of A/V usages, test and measurement equipment, computers or industrial designs. UL recognized, SEV and VDE approved. Rated at 20A/250VAC.
• Connector: PowerCon® chassis connector • Type: Power Out • Color: Gray (B) • Termination: For use with 0.187" x 0.020" quick-connect terminals • Mfg. #NAC3MPB
Note: PowerCon® is not designed to be a "mains" connector or for speaker/amplifier applications. For speaker applications please see the Speakon® series.
  • ConfigurationNeutrik powerCON
  • Power Connector TypeChassis / Panel Mount
  • Current Rating20A
  • BrandNeutrik
  • ModelNAC3MPB
  • Part Number092-286
  • UPC7613187007514
  • Product CategoryAC Power Connectors
    (3 Reviews)
  • Weight0.1 lbs.
View similar products to the Neutrik NAC3MPB powerCON Chassis Connector Power Out Gray
in the AC Power Connectors product category.
Neutrik NAC3MPB powerCON Chassis Connector Power Out Gray is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Solid connectorsThese are fairly easy to wire-up. Good, reliable connectors!
Date published: 2015-04-27
Rated 5 out of 5 by from The bestNeutrik is the best. Period. I like the locking mechanism so your cables never come loose. Ingenious and easy. I have several of these. Both 'In' & 'Out' connectors are great.
Date published: 2013-01-20
Rated 5 out of 5 by from Simplicity at it's bestYou can't go wrong. Use them,and you will never go back.
Date published: 2009-03-09
  • 2016-02-11T06:51CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_092-286, PRD, sort_mostRecent
Dimensions
Do these fit in a cutout for an XLR Female type connector?
Asked by: AT Johnson
Download the PDF drawing at this location:http://www.neutrik.com/zoolu-website/media/document/5733/Drawing+NAC3MPB-1The diagram gives the dimensions.
Answered by: jmarchitect
Date published: 2012-04-21
  • 2016-02-11T07:47CST
  • loc_en_US, sid_092-286, PRD, sort_recentQuestionsFirst
