Neutrik NAC3MPA-1 powerCON Chassis Connector Power In Blue
Brand:|Model: NAC3MPA-1|Part # 092-284
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. • Connector: PowerCon® chassis connector • Type: Power In • Color: Blue (A) • Mfg. #NAC3MPA
$2.99
Buy 25-99 $2.89
Buy 100+$2.68
Part # 092-284
  • 3-conductor quick disconnect terminations for easy and reliable assembly
  • Field serviceable, robust, and unbreakable
  • Fail-safe, long life electrical termination integrity
  • Developed for frequently connected/disconnected systems with operator and equipment safety in mind
PowerCon® is a lockable 3-pole equipment (AC) connector with contacts for line, neutral and premating safety grounds. Color coded for easy identification, PowerCon® offers power-in (blue) and power-out (gray) versions with different keying to avoid the possibility of short circuiting. The contacts are designed to prevent damage from arcing when disconnected while under load. PowerCon® meets or exceeds the demands of applications in the fields of A/V usages, test and measurement equipment, computers or industrial designs. UL recognized, SEV and VDE approved. Rated at 20A/250 VAC.
• Connector: PowerCon® chassis connector • Type: Power In • Color: Blue (A) • Termination: For use with 0.187" x 0.020" quick-connect terminals • Mfr. #NAC3MPA
Note: PowerCon® is not designed to be a "mains" connector or for speaker/amplifier applications. For speaker applications please see the Speakon® series.
  • ConfigurationNeutrik powerCON
  • Power Connector TypeChassis / Panel Mount
  • Current Rating20A
  • BrandNeutrik
  • ModelNAC3MPA-1
  • Part Number092-284
  • UPC7613187007408
  • Product CategoryAC Power Connectors
    (8 Reviews)
  • Weight0.1 lbs.
View similar products to the Neutrik NAC3MPA-1 powerCON Chassis Connector Power In Blue
in the AC Power Connectors product category.
