Neutrik NA4LJX Speakon To 1/4" Mono Jack Adapter
Brand:|Model: NA4LJX|Part # 092-065
Quickly and easily converts Speakon® NL4 amplifier outputs or speaker cabinet inputs for use with standard 1/4" speaker cables.
List Price$15.95
You Save55%
$7.15
Buy 25-99 $6.89
Buy 100+$6.49
Part # 092-065
  • Quickly and easily converts Speakon NL4F for use with standard 1/4" speaker cables
  • Speakon system offers the "quick lock" locking system
  • Contacts are touch proof and designed to prevent damage from arcing if disconnected under load
Quickly and easily converts Speakon® NL4 amplifier outputs or speaker cabinet inputs for use with standard 1/4" speaker cables. Neutrik's Speakon® series of professional speaker and amplifier connectors are recognized as the industry standard. Patent protected, reliable, cost effective, and extremely durable the Speakon® system offers the "quick lock" locking system.
The contacts in this series are touch proof and designed to prevent damage from arcing if disconnected under load. Ensuring fail-safe conditions for both the equipment and the operator. Speakon® meets the prevailing safety standards of IEC65, IEC348, CE, CSA and are UL rated (file #E135070).
Specifications: • Connector type: Adapter 1/4" 2-pole phone jack (6.3 mm) to Speakon • Connects "1+" to Tip and "1-" to Sleeve of 1/4" jack • Same dimensions as NL4FC • Mfg. #NA4LJ.
  • BrandNeutrik
  • ModelNA4LJX
  • Part Number092-065
  • UPC7613187004810
  • Product CategoryspeakON / HPC Adapters
    (45 Reviews)
  • Weight0.12 lbs.
View similar products to the Neutrik NA4LJX Speakon To 1/4" Mono Jack Adapter
in the speakON / HPC Adapters product category.
Neutrik NA4LJX Speakon To 1/4" Mono Jack Adapter is rated 4.8 out of 5 by 45.
Rated 5 out of 5 by from Nice Alternative to WiringI was going to clip the end of my cable and solder Neutrik tips on. Instead I found these. End result is that I keep my cables intact and can use these adapters on my subs and the old 1/4" does not get blown out of the jack
Date published: 2015-06-03
Rated 5 out of 5 by from Neutrik ConnectorsI am enthused about Neutrik Speakon connectors. They are not subject to the 1/4" small spot spring connection point but rather have an extended bar area to handle many amps of current. Also, the design is self locking, can be firmly strain-relieved, and will not fall apart.
Date published: 2015-03-08
Rated 5 out of 5 by from BEST ADAPTER TO HAVE WITH YOU!i PLAY BASS AND i HAVE A NUMBER OF SPEAKER CABINETS THAT HAVE SPEAKON INPUTS AND BEING OLD SCHOOL I HAVE A LOT OF 1/4" SPEAKER CABLES. tHESE NEUTRIK ADAPTERS HAVE NEVER FAILED ME AND SAVE ME MONEY NOT TO UPDATE TO ALL NEW SPEAKON CABLE.KOODOO'S TO NEUTRIK FOR MAKING A GREAT ADAPTER.
Date published: 2015-03-04
Rated 5 out of 5 by from Fixes the problem with using old 1/4 speakersJust the component you need for a new amp to still use you oldspeakers speakers
Date published: 2014-12-06
Rated 5 out of 5 by from Easy to understandJust one of those parts that you need when using German made electronics to convert it to standard. great part
Date published: 2014-10-15
Rated 5 out of 5 by from Great productNeeded these for power amp output that no 1/4 " jacks. Works great.
Date published: 2014-09-20
  • 2016-02-10T07:01CST
  • co_hasreviews, tv_0, tr_45
  • loc_en_US, sid_092-065, PRD, sort_mostRecent
How to open a Adaptor connector to intall the cable wire?
Asked by: Binh
This is not meant to be opened. This is designed to adapt a 1/4" mono speaker cable into a standard 2 pole Speakon connection.
Date published: 2015-02-17
Which Neutrik adapter will I need to use the bridged output on my behringer EP 2500 Power Amp
Asked by: fred61
This is the only Neutrik adapter of this nature we carry. It would be suitable for your application. In order to operate your Behringer amplifier in bridged mode, you simply use the positive output connection from both channels (1+/2+), rather than positive and negative. Any connector with two or more conductors will accommodate this.
Answered by: RussR
Date published: 2011-05-13
  • 2016-02-10T07:55CST
  • loc_en_US, sid_092-065, PRD, sort_recentQuestionsFirst
