Muffin Cooling Fan 115 VAC 117 CFM 4-5/8" x 1-1/2" A1V12C38TST-IU
Brand:|Model: A1V12C38TST-IU|Part # 259-150
Popular, high output 117 CFM 120 mm AC fan used in larger electronic equipment and rack cooling features a 5-blade plastic impeller and aluminum alloy frame. Power cord not included. Made in Taiwan.
List Price$23.99
You Save47%
$12.80
Buy 4+$11.50
Part # 259-150
  • Standard 120 mm x 120 mm x 38 mm frame size
  • 5-blade plastic impeller
  • Rugged aluminum alloy frame
  • Sleeve bearing
Popular-sized, high output 117 CFM AC fan that's used in larger electronic equipment and rack cooling features a 5-blade plastic impeller and aluminum alloy frame. Power cord not included. Made in Taiwan.
Specifications: • Input voltage: 115 VAC • Frequency.: 50/60 Hz • Current: 0.26/0.21 A • Power: 20/16 W • Maximum air flow: 117 CFM • Noise: 44/48 dBA • Bearing system: Sleeve • Dimensions: 4-5/8" H x 4-5/8" W x 1-1/2" D (120 x 120 x 38 mm) • Mounting holes: 4-1/8" (105 mm) O.C. • Safety approvals: CE, UL recognized • Model: A1V12C38TST-IU.
  • Operating Voltage110~120 VAC
  • Size120 mm
  • Bearing TypeSleeve Bearing
  • BrandParts Express
  • ModelA1V12C38TST-IU
  • Part Number259-150
  • UPC844632039515
  • Product CategoryEquipment Cooling
    (10 Reviews)
  • Weight1.25 lbs.
View similar products to the Muffin Cooling Fan 115 VAC 117 CFM 4-5/8" x 1-1/2" A1V12C38TST-IU
in the Equipment Cooling product category.
Muffin Cooling Fan 115 VAC 117 CFM 4-5/8" x 1-1/2" A1V12C38TST-IU is rated 4.0 out of 5 by 10.
Rated 4 out of 5 by from Moves a lot of airI bought 3 of this fan to be on my yamaha aventage receiver that runs very hot, place on top of receiver, this fan moves a lot of air the receiver is running cool now the only issue is its very noisy, so I end up getting a different fan that has a low cfm but I am keeping it for future use.
Date published: 2015-06-15
Rated 4 out of 5 by from Great fan for the price, but a bit noisy.I bought this fan about a month ago to replace the burned out cooling fan on the inverter in my camper. It really moves the air!!! My only complaint would be the noise. I've since decided to pull this fan from the inverter & go with a smaller/quieter fan as the inverter is under a bed & the noise is just too much when sleeping.
Date published: 2014-07-21
Rated 4 out of 5 by from Slight miss direction with positive purchaseIf thI first saw this fan advertized in one of your limited offer flyers When I call Parts Express company, I found that the fan was still being offered "at a $4 increase". I must say however this is still the best price on this quality metal fan that I have seen. I ordered Two. If the fan had a ball bearing shafts might it be a solid 5 star product.
Date published: 2010-09-09
Rated 4 out of 5 by from if it works its okI ordered 8 of these low coast fans to make dust collectors for my shop. When I opend the box I found 2 fans damaged ( which were replaced ) and when hooking up found 2 not to work . These I havent received yet. The dust collectors are working great though....
Date published: 2009-10-20
Rated 4 out of 5 by from High volume fan for low bucksOf course, it's noisy, (I've heard worse) I figured it would be when you can move this much air. The best cooling fan for the money. I quieted it by using rubber grommets and nylon screws.
Date published: 2009-06-09
Rated 4 out of 5 by from JUST WHAT I NEEDEDNormally used to cool large power amps, etc., I needed this one for use in conjunction with my wood pellet stove to spread heat through my 10 room (2400 sq. ft.) 160 yr. old. farm house. Perfect!Be nice if it was offered with a power cord and in line switch.
Date published: 2008-10-28
  • 2016-02-07T06:55CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_259-150, PRD, sort_mostRecent
How loud is this fan?
Asked by: mikeback9
The manufacturer rates the noise level at 43/47 db(a).
Answered by: GregT
Date published: 2015-05-27
Is this fan 120 volts a c.
Asked by: shortrod
Yes this fan will work on 110-120 VAC.
Date published: 2015-03-20
Is this fan available in 230 VAC power?
Asked by: JoeG
Unfortunately no, this is not available in that voltage.
Date published: 2014-07-17
Does the fan come with a power cord?
Asked by: Smnick95
This particular fan does not include the power cable. Check out the "My product recommendations" for the other parts you would need.
Answered by: mikevv
Date published: 2011-02-18
  • 2016-02-07T07:50CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_259-150, PRD, sort_recentQuestionsFirst
