MTX TDX35 Thunder 3-1/2" Coaxial Speaker Pair
Brand:|Part # 267-659
The TDX35 has 25 watts power RMS and up to 50 watts peak. With a wide frequency response, you will hear all of the music without missing a single note.
With an all new cosmetic upgrade, Thunder Dome-Axial speakers are still the best coaxial speaker on the market and are designed to compliment any installation while delivering a full range sound experience for all types of music. In order to get the most out of your music and hear it as the artist that recorded it intended you to, you need speakers that can reproduce the full range of sound frequencies. Thunder Dome-Axials are designed to do exactly that. The TDX35 has 25 watts power RMS and up to 50 watts peak power. With a wide frequency response, you will hear all of the music without missing a single note. Simple design for easy installation. Thunder Dome-Axials can be used as factory replacement speakers or in amplified systems to maximize their performance.
Specifications: • Description: 3-1/2" coaxial • Cone: Polypropylene • Tweeter: 20 mm PEI • Pivoting tweeter: No • Impedance: 4 ohm • Frequency response: 83 Hz-20 kHz • Power handling: 25 watts RMS/50 watts peak • Sensitivity (@ 2.83V): 92 dB • Mounting depth: 1-1/2" • Cut-out diameter: 3-1/16" • Grill: No.
  • Speaker Size3-1/2"
  • Speaker Type2-Way
  • Power Handling (RMS)25 Watts
  • BrandMTX Audio
  • Part Number267-659
  • UPC715442170999
  • Product CategoryDash, Door & Deck Car Speakers
  • Unit of MeasurePR
  • Weight2.34 lbs.
View similar products to the MTX TDX35 Thunder 3-1/2" Coaxial Speaker Pair
in the Dash, Door & Deck Car Speakers product category.
Videos
