302-018_ALT_0
302-018_ALT_1
MTX Monitor 6C Dual 6-1/2" 2-Way Center Channel Speaker
Brand:| Model: Monitor 6C
The Monitor 6C is a top performing center channel speaker designed to complete any home theater. As one of four models in the completely redesigned Monitor series, the Monitor 6C is timbre matched to the rest of the family and easily integrated to a full high performance system.
  • Two 6-1/2" woofers provide dynamic yet non-boomy bass
  • 19 mm PEI dome tweeter for balanced, articulate high frequency response
  • Magnetically shielded for placement near sunsitive equipment and media
  • Voiced to match the entire line of MTX Monitor series speakers
302-018
Weight: 13 lbs.
IN STOCK
Order Soon - Only 3 Left In StockMore Due In August 7, 2015
List Price$129.95
You Save23%
$99.95
Part # 302-018
The Monitor 6C is a top performing center channel speaker designed to complete any home theater. As one of four models in the completely redesigned Monitor series, the Monitor 6C is timbre matched to the rest of the family and easily integrated to a full high performance system. Two 6-1/2" woofers and a 19 mm PEI dome tweeter enhance this center channel's frequency response and sound clarity to provide exact sound reproduction and a realistic performance. The Monitor 6C features magnetic shielding of all drivers to allow the speaker to be placed in close proximity to video equipment. Plus, the Monitor 6C is also made with high quality materials like polypropylene woofer cones with rubber surround and its PEI dome tweeter for increased durability. Engineered from the ground up for accurate sound and exceptional imaging in real world situations, the Monitor 6C is in line with the high standards of performance expected from MTX. Sold individually.
Specifications: • Woofer: 6-1/2" poly • Tweeter: 19 mm dome • Frequency response: 63-20,000 Hz • Impedance: 8 ohms • SPL: 92 dB 2.83V/1m • Dimensions: 7-1/2" x 17-5/8" x 8" • 13.5 lbs.
  • Input Rating8 ohm
  • Woofer Diameter6-1/2"
  • Configuration2-way (MTM)
  • ColorBlack
  • BrandMTX Audio
  • ModelMonitor 6C
  • Part Number302-018
  • UPC715442650255
  • Product CategoryCenter Channel Speakers
    (16 Reviews)
  • Weight13 lbs.
View similar products to the MTX Monitor 6C Dual 6-1/2" 2-Way Center Channel Speaker
in the Center Channel Speakers product category.
MTX Monitor 6C Dual 6-1/2" 2-Way Center Channel Speaker is rated 4.4375 out of 5 by 16.
Rated 4 out of 5 by from Nice SpeakerI'm using this as the center channel in my 5.1 HT setup. Plenty of power, good clarity and decent balance. Seems to favor the higher frequencies, which is what is needed for the center channel.
Date published: 2015-02-03
Rated 5 out of 5 by from Good deal as part of a configurationI purchased this set for under $500 total:DAYTON AUDIO SUB-1200 12" 120 WATT POWERED SUBWOOFERMTX MONITOR 60I DUAL 6-1/2" 2-WAY BOOKSHELF SPEAKER PAIRMTX MONITOR 6C DUAL 6-1/2" 2-WAY CENTER CHANNEL SPEAKERMTX MONITOR 5I 5-1/4" 2-WAY BOOKSHELF SPEAKER PAIRI’m not an expert, but from my perspective, this (or similar) configuration is all you need for a good size family room. My family room is 20’ by 13’ and it fully opens to a kitchen of the same size (all speakers are set up in the room itself). I can now hear the music load and clear, even in the kitchen. In my experience, a more difficult challenge for speaker systems is to be able to hear a conversation from a TV program at a longer distance. With this set, I can also hear a conversation from a TV load and clear (!) even when doing something in the kitchen in a distance of about 40’ (and I have some hearing difficulty). BTW, a 100 Watt subwoofer might have been sufficient, but the price was the same at the time, so I bought 120 Watts.It seems that buying this type of configuration is a better deal than a Home Theater Speaker System.However, make sure you have enough space for the speakers (pretty large) and space on the floor for the subwoofer, which is large and heavy (you may need to explain to your spouse that it just needs to be like that :-)).
Date published: 2012-10-21
Rated 4 out of 5 by from i was very impressedi have been in audio for a long time and i have always had issues with center channels it always seemed the centers were always inefficient and take a lot of power to to reach loud levels i havent had a chance to fully test this center yet but i am impressed thus far and will write more when i get off work i am very impressed with this center
Date published: 2011-12-16
Rated 4 out of 5 by from Great SpeakerOut of all the center speakers I tested, I decided on this one from Parts Express. I couldn't listen to it, but knew If I didn't like it, I could return it. This is the best center speaker I've heard...Handles the Power well, and is very crisp and clean. ( as a center speaker should be....)I recommend it for all 5.1 and up configurations
Date published: 2010-08-03
Rated 5 out of 5 by from Very happyThe MTX Center Channel speaker is performing very well for me. Voices are clear, does not take a lot of power to drive.
Date published: 2010-03-05
Rated 5 out of 5 by from Clear DialogBought it for my mom along with the MTX 60i for the front and 5i for the rear this 6c center channel has wide dynamic range, clear and legible dialog, and is perfectly timbre matched to the rest of the set.Quality craftsmanship.
Date published: 2009-05-07
  • 2015-07-29T06:27CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_16
  • loc_en_US, sid_302-018, PRD, sort_mostRecent
Customer projects that include: MTX Monitor 6C Dual 6-1/2" 2-Way Center Channel Speaker
