MTX JH805 JackHammer 4x75W + 1x500W Amplifier
Brand:|Part # 267-634
JackHammer 75 watt x 4 + 1 x 500 watt 5-channel amplifier is designed to deliver all the power you could ever want to run your subwoofer or enclosure.
Part # 267-634
  • Patented Pure N-Channel Technology
  • Patented Adaptive Class D Technology
  • Patented Power Supply
  • Variable Crossover (Front): High @ 40 Hz to 5,000 Hz, 12 dB/Oct
  • Variable Crossover (Rear): Low @ 40 Hz to 5,000 Hz, 12 dB/Oct; High @ 40 Hz to 8,000 Hz, 12 dB/Oct
  • Variable Crossover (Sub): Low @ 40 Hz to 200 Hz, 24 dB/Oct
  • Subsonic Filter: 20 Hz to 50 Hz, 12 dB/Oct
With a name like JackHammer you have to be able to deliver power. As an addition to the JackHammer series of subwoofers comes JackHammer amplifiers. These amplifiers are designed to deliver all the power you could ever want to run your JackHammer subwoofers or JackHammer enclosure. JackHammer amplifiers bring the pain with six models that fit any need in any installation. They use patented and proven MTX designs which keep them running for as long as you need them. JackHammer amplifiers incorporate Active Fan Cooling technology which controls fan speed based on volume level, the louder you crank it the faster the fan spins to deliver cool air to the interior of the amp where its needed to play louder and longer. JackHammer amplifiers have a sexy style with their gloss black finish and large JackHammer badge. They also incorporate a new design that allows them to be stackable. Using the included "JackStands", you can stack up to three amplifiers on top of each other with a simple push and twist, no hassles required.
Specifications: • Power output: 37.5 Watts RMS x 4 and 250 Watts RMS x 1 at 4 Ohms, 75 Watts RMS x 4 and 500 Watts RMS x 1 at 2 Ohms, 150 Watts RMS x 2 Bridged at 4 Ohms and 500 Watts RMS x 1 at 2 Ohms • Signal-to-noise ratio (1 Watt): 75 dB (Front/Rear), 70 dB (Sub) • THD+N (Distortion) (1 Watt): <1% • Frequency response (-3 dB): 20 Hz to 20 kHz • Maximum input signal: 5V • Dimensions: 17-3/8" x 8" x 2-3/8".
  • BrandMTX Audio
  • Part Number267-634
  • UPC715442241361
  • Product CategoryCar Amplifiers
  • Weight12.6 lbs.
View similar products to the MTX JH805 JackHammer 4x75W + 1x500W Amplifier
in the Car Amplifiers product category.
